Thread: LTFT Issues?
Results 1 to 6 of 6
  1. #1 LTFT Issues?
    Donating Users Joe's Avatar
    Waterloo, IA
    I have two log files with the LTFT up to 16.4 and as low as -20. Is an untuned car really this far off or do I have another problem? (Vacuum leak?, exhaust leak?) I've replaced all the vacuum lines and went through a can and a half of carb + choke cleaner looking for leaks and came up with nothing. The bolt holding the EGR tube to the LIM was loose but tightening that did nothing for my LTFT.
    Log File 1
    Log File 2
    2000 Grand Prix GTP
    e: JTuckGTP@gmail.com
  2. #2 Re: LTFT Issues?
    Feb 2009
    flintnasty MI
    Untuned? With what mods?
    The only thing that "requires" a tune is a huge cam (huge), or different maf/throttle body / injectors.
  3. #3 Re: LTFT Issues?
    Waterloo, IA
    Ported rear manifold(had a powerlog till it rusted out) Racetronix fuel pump, 180 t-stat, U-bend delete, Spectra Filter. Not much to help with airflow so I'm assuming its normal, just never noticed it. Just don't want to try to tune out something I should fix.
    2000 Grand Prix GTP
  4. #4 Re: LTFT Issues?
    Feb 2009
    flintnasty MI
    so, stock.
    LTFT should be around +-3 on a stock car at cruise/wide open. Idle/decel things may get weird but its probably not a big deal.
  5. #5 Re: LTFT Issues?
    Pull that EGR tube off and look for the crack in it where it meets the LIM. It's usually there.
  6. #6 Re: LTFT Issues?
    Waterloo, IA
    That was it. Small crack but was enough to mess with my fuel trims. Thank you.
    2000 Grand Prix GTP
  1. ltft?
    By jim97regalgs in forum PCM Tuning
    Last Post: 10-14-2011, 09:01 PM
  2. ltft chasing
    By shawnrandolph in forum PCM Tuning
    Last Post: 08-31-2011, 10:53 AM
  3. 16.4 LTFT at idle with E85
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2010, 03:24 PM
  4. LTFT all over
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 10:07 AM
  5. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
