Thread: These numbers look ok enough to start adding timing?
Results 1 to 12 of 12
  1. #1 These numbers look ok enough to start adding timing?
    Chicago
    I havent had a chance to rip the wideband off my mustang yet to tune the gp but im hoping to get to it this weekend. How do these numbers look so far and do you think i can start adding a little timing? I dont know what the kr blip is and if i should be concerned about it. First scan was 1st gear and 2nd scan was 2nd gear. Thanks!
    Device Time Engine RPM(rpm) Knock Retard(Deg.) Timing Advance(°) Throttle Position(Manifold)(%) H2OS Sensor(mV)
    56:33.4 979.75 0 33 0 286.4400024
    56:34.3 2530.5 0 21 27.05882454 95.48000336
    56:35.3 2997.5 0 12.5 43.92156982 898.3800049
    56:36.3 3847.75 0 14 47.84313965 915.7399902
    56:37.3 4314.5 0 12 100 920.0800171
    56:38.3 5552.5 0 12 100 920.0800171
    56:39.3 6120.75 0 10.5 100 924.4199829
    58:29.6 1610.5 0 28 3.92156863 772.5200195
    58:30.6 3018.25 0.615234 -4 100 902.7199707
    58:31.6 3904.75 0 12 100 907.0599976
    58:32.6 4012 0 11.5 100 911.4000244
    58:33.6 4272.5 0 11.5 100 902.7199707
    58:34.6 4445.75 0 12 100 907.0599976
    58:35.6 4838 0 12 100 911.4000244
    58:36.6 5022.75 0 12 100 902.7199707
    58:37.6 5201.5 0 12 100 902.7199707
  2. #2 Re: These numbers look ok enough to start adding timing?
    I'm no expert but if your only running 12* of timing at WOT you need to add some timing or more flow mods plus more timing.
  3. #3 Re: These numbers look ok enough to start adding timing?
    That little blip is prolly when you first go into PE mode.
    And yeah only 12* of timing at WOT is really low.
    Just wondering, what mods do you have?
    And IIRC stock WOT timing is around 15-16*
  4. #4 Re: These numbers look ok enough to start adding timing?
    Chicago
    Yeah i know its a little low but I wanted to try and get the o2 in range before adding timing. I really need to get my wideband hooked up and go from there.
    Mods are 3.4/FWI/104's/u bend delete/180* stat. I think i need to get headers and see what kind of timing I can run. Im going to add a little more fuel and start playing with the timing. Im going to get the wideband on this weekend and see where im at.
  5. #5 Re: These numbers look ok enough to start adding timing?
    You need to run at least 16* of timing and see how much KR you are getting with a good AFR then add flow mods until you have no KR.
  6. #6 Re: These numbers look ok enough to start adding timing?
    yes, you need headers.
    If you arent getting any KR now, I bet its running stupid rich to try and drown out the knock.
    3.4 with only a ubend delete is not enough in my honest opinion.
  7. #7 Re: These numbers look ok enough to start adding timing?
    Charles City, IA
    Guess by your narrow band reading, you are a little lean, so once you get the wideband on add fuel if needed then add timing.
    SMGPFC Two Nipple General
  8. #8 Re: These numbers look ok enough to start adding timing?
    Chicago
    Thanks for all of the info. I bought the car about 2 months ago and the previous owner obviously didnt do things correctly. In fact he didnt even have the U bend installed. He gave it to me with the car so I went ahead and put it on myself. They couldnt get it to pass emissions so I got it for 800 bucks lol. The only reason the CEL was on is because it had a bad vacuum leak. Now im just trying to get the car where it should be. I even thought about trying to get a stock pulley for it and go from there. For now I can tune around it but i dont know how much timing i can run yet, I havent pushed it that far.
  9. #9 Re: These numbers look ok enough to start adding timing?
    Charles City, IA
    18-20 is the top end of what ya want to run on pump gas.
  10. #10 Re: These numbers look ok enough to start adding timing?
    Feb 2009
    flintnasty MI
    Quote Originally Posted by TheOtherNick View Post
    Still probably in the 10.x:1 afr range.
  11. #11 Re: These numbers look ok enough to start adding timing?
    Chicago
    Ive been slowly adding timing and scanning. This is what I have so far. Do I just keep adding timing until it starts to show kr then take 1* out? It seems to be running pretty strong right now.
    Engine RPM(rpm) Knock Retard(Deg.) Timing Advance(°) Throttle Position(Manifold)(%) H2OS Sensor(mV) Speed (OBD)(mph)
    2125.75 0 26.5 18.8235302 594.5800171 12.42742419
    2685.5 0 26.5 21.56862831 108.5 15.53428024
    4204.25 0 13 47.45098114 915.7399902 35.41815895
    4617.25 0 16 100 933.0999756 36.03953016
    5022.75 0 16.5 100 933.0999756 43.49598467
    5672.25 0 15.5 100 937.4400024 49.70969677
    4191 0 16 100 928.7600098 60.89437854
    4343 0 16 100 928.7600098 65.86534822
    4569.25 0 16.5 100 924.4199829 70.8363179
    4785.25 0 16.5 100 924.4199829 75.18591636
  12. #12 Re: These numbers look ok enough to start adding timing?
    Keep adding timing until you get KR.
  1. are these numbers right?
    By GenVI805 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2011, 09:16 AM
  2. adding remote start to an 05
    By 05grandprixgt in forum General Tech Discussion
    Last Post: 02-01-2010, 08:15 AM
  3. Timing and other numbers...
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2009, 07:36 AM
  4. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  5. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
