Thread: PCM Stopped Working After Running For A Little
Results 1 to 7 of 7
  1. #1 PCM Stopped Working After Running For A Little
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    I just got done doing my top swap on my 98 gp gt and everything went good started it and ran perfect, couple days later I went to finish my exhaust and went to start it and would not start. I spayed some starting fluid in and fired up but only would stay running if I held the gas down a little, I pulled the gtp pcm and put my gt one back and it fired right up and ran perfect. So I pulled that one back out and put back the gtp and still no start. I have fuel, spark,but i don't think the gtp pcm is firing the injectors. Any ideas?
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  2. #2 Re: PCM Stopped Working After Running For A Little
    So it only stay runnin if you hold the gas pedal down.
    Have you tried unplugging the MAF sensor and see if it changes?
  3. #3 Re: PCM Stopped Working After Running For A Little
    Jun 2011
    Watertown, SD
    I have to spray some starting fluid in it then it will start but dies after it burns that up.
    Ok I unpluged the maf sensor and it started kinda. it would fire but I couldn't keep it going
  4. #4 Re: PCM Stopped Working After Running For A Little
    Donating Users SarasotaGTP's Avatar
    Nov 2011
    Sarasota Florida
    are you disconnecting the battery when you swap out pcm's? if not might wanna try that. I am not sure but I think I remember hearing that when u swap pcm's that if you leave battery connected some of the stuff will stay "loaded" in the car somehow and mess with the new/swapped pcm. Just a thought. GL
  5. #5 Re: PCM Stopped Working After Running For A Little
    Jun 2011
    Watertown, SD
    Yea I left the battery disconnected for about 30 mins
    Which tb and injectors are you running and which trans?
  7. #7 Re: PCM Stopped Working After Running For A Little
    Jun 2011
    Watertown, SD
    L67 tb and inj, pcm been programed for the 4t65e
  1. Cluster Stopped working.
    By Carlos773 in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2012, 08:25 PM
  2. odometer stopped working help?
    By itsvo09 in forum Audio, Security & Visual Electronics
    Last Post: 11-02-2011, 04:07 PM
  3. Tap shift Stopped working
    By dlemmen in forum General Tech Discussion
    Last Post: 06-16-2011, 07:29 PM
  4. air con stopped working
    By Tha Ghost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 04:14 PM
  5. My Controls Stopped Working
    By OverMyHead in forum Audio, Security & Visual Electronics
    Last Post: 12-17-2009, 08:48 AM
