Thread: idle issues.
Results 1 to 20 of 25
  1. #1 Re: idle issues.
    TDCRacing
    Guest
    May have figured this out. will post up later tonight.
  2. #2 Re: idle issues.
    TDCRacing
    Guest
    Well After my exhaust fell off while driving, I went back home and re-attached the Y-pipe to the rear header and crossover once again. This time it made a little better seal than it did last time....but is STILL leaking pretty bad. Anyway after this the surging stopped. It was Leaking pretty bad before also. I mean I cant belive it was something that simple yet I went through hell trying to find it. I mean I unplugged almost every sensor that the car has on it,even the O2 sensor trying to trouble shoot this problem....o well....I knew the surging had gotten worse so i was trying to think of parts or other problems that had gotten worse also. Those two things were spark plugs and the leaking exhaust....
    So i guess this problem like many others was kind of like ''Where's waldo''....You look for ever and when you finially find his ass he was right in front of you the whole time.
    I cant belive I Over looked my biggest on going problem that i've had with the car while trying to trouble shoot this new problem.
    So thanks again for all of the help and suggestions.
  1. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  2. Low idle at Stop Sign
    By offroadfury6 in forum General Tech Discussion
    Last Post: 08-10-2008, 06:26 PM
  3. Replies: 5
    Last Post: 05-11-2008, 07:10 PM
  4. Rough/hunting idle
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2008, 11:22 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
