Thread: Tuner all of a sudden wont connect to car?
Results 1 to 18 of 18
  1. #1 Tuner all of a sudden wont connect to car?
    Kansas
    Been working fine for months.
    took off old injectors put on new so been working on the tune for MAF and now it wont connect.
    Its not getting power since the red light wont even come on when plugged in but it works fine when plugged into other vehicles.
    Any help?
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Tuner all of a sudden wont connect to car?
    Donating Users moddman's Avatar
    Midwest
    Check your cig lighter fuse. Make sure the cig lighter works since it gives power to the data connector.
  3. #3 Re: Tuner all of a sudden wont connect to car?
    Florida
    I got so super ****ing pissed trying to get my Aeroforce to work....
    Turns out it's that cig lighter fuse...
    +1 for a good idea moddman
  4. #4 Re: Tuner all of a sudden wont connect to car?
    Kansas
    no ****ing way thats what does that!
    Thats my problem then cause its pulled out.. I blew it when trying to charge my laptop from the cig lighter and have not replaced it.. I will do that today thanks
  5. #5 Re: Tuner all of a sudden wont connect to car?
    GT Level Member tylerbinski's Avatar
    Canada
    Had same problem. Turned out to be 4 broken wires in the serial cable ... hehe
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  6. #6 Re: Tuner all of a sudden wont connect to car?
    Topeka, KS
    If you don't have a fuse a bubble gum wrapper (foil) on your burnt fuse works too
  7. #7 Re: Tuner all of a sudden wont connect to car?
    Midwest
    Quote Originally Posted by rynoman03 View Post
    Technically it does work temporarily......but if you get any kind of short.....you could start your car on fire by burning wires leading from your fuse box all the way up to the cig lighter......ouch.....
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  8. #8 Re: Tuner all of a sudden wont connect to car?
    Topeka, KS
    I didn't say it was a permanent solution lol. But it does work. Same goes with the 22 bullet in the older glass type fuses on older vehicles.
    This isn't a good idea by any means though. Sadly i've seen it done quite a few times.
    Baaaaaad idea
  10. #10 Re: Tuner all of a sudden wont connect to car?
    Topeka, KS
    I never said it was a good idea.
  11. #11 Re: Tuner all of a sudden wont connect to car?
    dont do any of those things. replace fuses with the same fuse for the love of christ. fuses are dirty ass cheap.
  12. #12 Re: Tuner all of a sudden wont connect to car?
    Omaha, NE
    Stock up on fuses from the junkyard. That's how I get them for free.
    3-4 fuse blocks fill an average sized pocket nicely.
  13. #13 Re: Tuner all of a sudden wont connect to car?
    Omaha, NE
    I don't want to get another infraction for telling you the improer way to aquire fuses. So... Here's a link to amazon.Amazon.com: 120 Assorted Car Truck Mini Fuse 5,7.5,10,15,20,25,30 AMP: Lamps & Light Fixtures
  14. #14 Re: Tuner all of a sudden wont connect to car?
    Feb 2009
    flintnasty MI
    I am pretty sure no junkyard will ever charge you for fuses.. I am positive they PAY to have thousands disposed of daily.
  15. #15 Re: Tuner all of a sudden wont connect to car?
    Kansas
    I know on 04+ if the Onstar fuse is blown or missing, then the communication of the OBDII port is inop.
  16. #16 Re: Tuner all of a sudden wont connect to car?
    SE Level Member midrange's Avatar
    Belleville, Ontario
    I have TONS of fuses by removing them from cars about ready to be crushed at wrecking yards..
    2004 Grand Prix GT1
  17. #17 Re: Tuner all of a sudden wont connect to car?
    Belleville, Ontario
    They don't pay for the disposal.. they stay in the car that gets crushed, and they get the money for the scrap. If they were smart, they would remove all fuses when a car arrives and sell them.. Fuses are expensive. Here anyways. Pack of 3 is around 5 bucks.
    2004 Grand Prix GT1
  18. #18 Re: Tuner all of a sudden wont connect to car?
    For the glow blow ones sure, but $5 for 5 of the traditional style.
  1. xbox wont connect to wifi
    By JarenSTi in forum Off Topic Discussion
    Last Post: 04-16-2010, 09:39 PM
  2. **FIXED**Can't get tuner to connect
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2009, 03:51 PM
  3. Tranny is slipping real bad all of a sudden
    By Sandman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2009, 04:41 PM
  4. so all of a sudden im motivated....
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2008, 10:44 PM
  5. Sudden tranny problems...
    By Blinksy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-05-2008, 12:16 AM
