Thread: Lucas 42.5 injector help
Results 1 to 20 of 28
  1. #1 Lucas 42.5 injector help
    SE Level Member Dthreap's Avatar
    ohio
    I just installed lucas 42.5lb injectors and they are doing great until I get around 90mph then my kr shoots through the roof and the car falls flat on its face. I scaled the Flow Rate vs KPA by taking my new 42.5lb and dividing it by my old 31lb then multiplying the table by 1.37096. I'm not sure if I need to edit any of the other injector tables because I can't really find any information on what needs to be done for these.
    Any help would be great.
    Here's my current tune, my log and I don't have the WB plugged in because the analog is in another car.
    hpt bin - http://upit.cc/f/b808484f.hpt
    log - http://upit.cc/f/51de7254.hpl
  2. #2 Re: Lucas 42.5 injector help
    Pennsylvania
    Not Found
    The requested URL /svn/trunk/Tunes/Derek's was not found on this server.
  3. #3 Re: Lucas 42.5 injector help
    ohio
    Sorry, edited with new links since my svn wants to act up today.
    Ohio
    Dumbass lol
  5. #5 Re: Lucas 42.5 injector help
    Portland Oregon
    I just did the same thing with my Bosch green top 42's that I put in. Even with the right IFR table it was silly lean. Do you have a wideband? I needed to maf tune it 5-6 times to dial it in.
    Ohio
    We'll be doing his and mine this week most likely
    ohio
    Yeah I have a wb, does it just need the maf retuned? What about the offset voltages?
  8. #8 Re: Lucas 42.5 injector help
    Portland Oregon
    To be honest I didn't touch the offset voltages. I just put in the modified IFR table and maf tuned it.
    ohio
    Okay ill see if a maf tune helps things. I should have more analogy input on there way this week so all the cars can have one
  10. #10 Re: Lucas 42.5 injector help
    ohio
    Hooked the WB up tonight and was idling around 18 afr. Did about 5 maf edits and got it much much closer to where I need to be. WOT still needs more fuel though since I'm only getting to 12.5 afr. And seeing as Duty Cycle is hitting 80% and my Pulse Width is at 19 I might just have to get 60lbers...
    Thanks againOH4CompG!
  11. #11 Re: Lucas 42.5 injector help
    If your mods are current in your signature.. likely you should be checking your fuel pressure.
  12. #12 Re: Lucas 42.5 injector help
    Feb 2009
    flintnasty MI
    Most scanners read 04+ IPW's incorrectly. You can take a 04+ to like 140-150% IDC with most scanners.
  13. #13 Re: Lucas 42.5 injector help
    Jan 1970
    Maquoketa, Iowa
    X2 returnless fuel
  14. #14 Re: Lucas 42.5 injector help
    Feb 2009
    flintnasty MI
    Quote Originally Posted by FoSHO99 View Post
    X2 returnless fuel
    No, broken scanner. The fact its returnless means very little... The regulator is not boost referenced, but it functions the same as a L67 regulator it just does not sit on the motor.
  15. #15 Re: Lucas 42.5 injector help
    How I read that suggests the L32 returnless is not boost referenced and functions the same as an L67.
    That to me means you're saying the L67 is not boost referenced.
    Leg spin time? I think so.
  16. #16 Re: Lucas 42.5 injector help
    Portland Oregon
    I'm with this guy. I took my stock injectors to 130% IDC before it started to lean out on the wideband. Also I had the same thing happen when I put my 42.5's in and I'm running a 2 year old 255lph pump
  17. #17 Re: Lucas 42.5 injector help
    Ohio
    see derek, told ya it might be time for a new pump :P
    yes bill those mods are all current to his car.
    ohio
    Quote Originally Posted by 99pgpgt View Post
    Mike you never said such things lol. And thanks for the tip dark.
  19. #19 Re: Lucas 42.5 injector help
    Ohio
    or did i?
    ohio
    That was someone else we know
  1. George Lucas in love
    By crshoveride in forum Off Topic Discussion
    Last Post: 01-20-2010, 01:00 PM
  2. Lucas Oil Stabilizer
    By millfire517 in forum General Tech Discussion
    Last Post: 02-10-2009, 10:14 PM
  3. lucas transimission fix
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-05-2008, 11:11 PM
