Thread: 3100 Governor Removal
Results 1 to 9 of 9
  1. #1 3100 Governor Removal
    SE Level Member Futures Passed's Avatar
    Dec 2011
    Florida
    I've gotten my car up to, let's say a certain speed which isn't really worth bragging about, but it gets there quite easily, and then it really dies down quick for the last two miles per hour. It feels like it has a lot more in it. Plus, my friend's car is limited to 2 MPH over what I'm limited to. Not cool.
    Is there any way to remove this limiter without buying that $500 HP Tuners kit? I have a USB-to-OBDII connection (from OBDCOM) already if that helps in any way.
  2. #2 Re: 3100 Governor Removal
    Charles City, IA
    nope, and there is no point to you dont need to be going that fast. If you cant hit the speed on teh track there is no need to go it.
    SMGPFC Two Nipple General
  3. #3 Re: 3100 Governor Removal
    Nope, it has to be removed from the PCM via a tune.
    And its not worth going any faster than you can trap in a 1/4 mile. Stick to 20-90 mph races.
  4. #4 Re: 3100 Governor Removal
    It being a 3100 why do you even bother trying to race anyone? They are crazy slow. 3100 love
  5. #5 Re: 3100 Governor Removal
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    The 3100 is still fun my mommys car had that when I used to be runnin dem streets @ 16. For real tho after I had my tune I went past my old "stopping" point and its no diffeent and honestly unless you got some real suspension work not a good idea unless at the track anyway
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  6. #6 Re: 3100 Governor Removal
    are your tires even rated for that fast?
  7. #7 Re: 3100 Governor Removal
    Add 3 mph to the what...108 mph limiter in the SE...winning?
  8. #8 Re: 3100 Governor Removal
    Dec 2011
    Florida
    Quote Originally Posted by gtpsleeper View Post
    I'm not going that fast on my current tires in their condition anyway. My next set will most likely be.
    I keep forgetting there isn't another gear after that.
    I do a lot of driving on empty highways and some closed off roads. I don't race in public, they pull enough stunts as it is at normal speed, and the last thing I need is for someone to not be guilty of texting while driving because I was over the speed limit.
  9. #9 Re: 3100 Governor Removal
    SE Level Member greenmachinegtp's Avatar
    Crossville, TN
    Why not do the toggled vss trick? and unless you got some serious mods there isnt any point in trying to wind that motor out in 4th, it will take a long time to climb up there and then it will blow, prolonged high rpm added to 3100 with no oil cooler plus heavy car that probably still has a cat = high temps. high temps = kaboom. unless you are fast enough to max it out in a quarter, you are gonna burn your bearings up trying to get up much over 120 or so. If you dont scorch the bearings the tranny is gonna cook man. you dont wanna do that to a 16.5 second car, its for getting groceries, not racing.
  1. speed governor
    By Glider Girl in forum General Tech Discussion
    Last Post: 07-26-2011, 10:13 AM
  2. Top Speed Governor/Limitor
    By udmercy35 in forum General Tech Discussion
    Last Post: 02-07-2011, 09:18 AM
  3. Top speed WITH GOVERNOR?
    By 05PontiacGP in forum General Tech Discussion
    Last Post: 10-16-2010, 09:36 AM
  4. rev governor
    By Sabzz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-04-2010, 07:31 PM
  5. 95 gp se 3100
    By mikedinthecity in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-13-2009, 12:05 PM
