Thread: Fried PCM
Results 1 to 3 of 3
  1. #1 Fried PCM
    May 2011
    Bremen,GA
    I was scanning my car last night trying to find a problem,then noticed my ltft's were spiking at +36.
    Showing no misfiring cylinders,scrolled down,primary misfiring cylinder-15,secondary misfiring cyl,-15.
    I thought that the highest ltft you could get was 16,and a big ? for the number 15 cylinder misfire.
    This pcm seems to be fried because the snap-on scanner has worked fine with the last 8 vehicles.
    Also have extra pcm from a regal with same service number,but security is enabled and it would not
    accept the security relearn.Thinking about running a ground to the anti theft pin and see if it enables fuel.
  2. #2 Re: Fried PCM
    It's cylinders 1 and 5
  3. #3 Re: Fried PCM
    May 2011
    Bremen,GA
    My scanner only shows one cylinder at a time for primary or secondary misfiring cylinder.
    It actually displayed a 15. As b.s as that may sound,that is why I think the brain is dead.
  1. fried rice first time
    By dazedandconfused in forum Track Sessions and Kills
    Last Post: 10-01-2011, 07:52 PM
  2. 02 fried under hood ign relay 11
    By rharper33 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2011, 09:14 PM
  3. Subs blown... amp fried? which one??
    By coreygnar in forum Audio, Security & Visual Electronics
    Last Post: 09-23-2010, 10:41 PM
  4. I fried my pcm today
    By 99prixgt in forum General Tech Discussion
    Last Post: 07-03-2010, 07:24 PM
  5. fried/bricked pcms?
    By glanzergtx in forum PCM Tuning
    Last Post: 10-02-2009, 04:24 PM
