Thread: opinions on zzp 1.0 PCM
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: opinions on zzp 1.0 PCM
    The tuner gives you ALL the possibilities you could ever want when tuning your Grand Prix...whereas a mail order tune (DHP, ZZP, Intense, Overkill, etc.) do things such as basic changes (shift points, line pressure increase, 40 mph skip shift, no speed limiter, fan turn on, etc.)
    The only difference from the tuner is the price and the vast amounts of knowledge you need for it to work correctly without messing up your car...I would love to learn it, but I would be afraid of messing something up IMO...hence why I leave it to the professionals
  2. #22 Re: opinions on zzp 1.0 PCM
    Jul 2008
    Poteau Oklahoma
    ok so I saw the thread from wiki about tuning.
    for a novice to start with a tuner what would be the best way to start that.
    dont want to spend the money for a new pcm and a tuner if the same can be done from my hands, or someone that would help me really understand this stuff when I get one.
    ( hint-hint) Ok. crew.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  3. #23 Re: opinions on zzp 1.0 PCM
    TDCRacing
    Guest
    Quote Originally Posted by justwhisen View Post
    Go to HPTuners.com >> Performance At Your Fingertips and read read read. None of it will make sense at all. This is normal. Thats the best thing you can do before you get a tuner. Or anything really. And that is to know and understand what your dealing with. As far as someone to help you when you get a tuner im here for you just to let ya know. Im no pro, but in reality no one really is. I know more than the basics as a handfull of other people on GPF also do. The only part I don't know a whole lot about is tuning with a wideband. But i'll be getting into that soon because i should have had one a long time ago.Any questions you have after reading up on hpt feel free to pm me. And you should be reading for weeks not days to start understanding the tuning aspect.
  4. #24 Re: opinions on zzp 1.0 PCM
    Jul 2008
    Poteau Oklahoma
    #1 wtf is wide ban? (yea yea yea) I see where people talk about this all the time. Rember I am used to just playing with carbs this is still a new game to me.
    #2 how is tuning with that different?
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  5. #25 Re: opinions on zzp 1.0 PCM
    TDCRacing
    Guest
    It's called a Wideband 02 sensor. All factory cars come with a narrow band wich is only accurate at an air/fuel ratio of 14.7. Well, in the tuning world an A/F ratio of 14.7 is not always the ideal Ratio to run. Especially if your cammed,boosted or intercooled. Anyway back on track, All a wideband is used for is to verify what the o2's are at....860's 920's ect are examples of what the o2's can be at. The narrowband o2 sensor works for some and has worked for me so far. But it is far from the ideal thing to have. This is a common experienced problem with the narrowband and people realize this after they get their wideband,We'll use o2's in the example of around 890-910 because at about 70-90 degrees is the ideal numbers for me to run taking into consideration my mods.-
    Narrowband o2's will read 890
    Wideband o2's will read 870
    Boom you no longer have an engine anymore because you ran to lean. The lower the o2's the less fuel you have. And FYI stock o2's on a gtp are around 960's.
    As for your second question im not quite sure. I mean the way of tuning doesen't really change. It's just what you use to tune. You can tune idle with a wide band for instance a lot better than wen your using a narrow band.
    Anything else i can help you with?
  6. #26 Re: opinions on zzp 1.0 PCM
    Jul 2008
    Poteau Oklahoma
    at this time that takes a lot of the shadows away for me. thank you if I have any more questions I will not hesitate to ask, this stuff still resembles Voo-Doo to me only better.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  7. #27 Re: opinions on zzp 1.0 PCM
    TDCRacing
    Guest
    No problem glad i could help
  1. Opinions on my MAF Tuning
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 08-11-2008, 07:40 PM
  2. Need a few opinions....
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-07-2008, 01:19 PM
  3. LQ4 with new zzp 78mm polished TB?? Need some opinions!
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2008, 03:48 AM
  4. Before and After (Opinions Wanted)
    Last Post: 01-16-2008, 11:04 PM
