Lambda is what the sensor measures.
But if you know which range is which in the gasoline scale, then what does it matter?
Unless however you wish to have your PCM know its not running gasoline.
In which case you'd change it to read stoich as the stoich of your fuel.
Then adjust all of your commanded AFR's to match the new scale.
Benefit?
Unsure.
