Ok well I just recently got a dhp tuner from a member on here. I have 1999 grand prix gt. It has been topswapped and tuned by someone other than me..
Here is my problems. I get the thing to register on my computer and all goes well. I read the pcm that works fine. Then I go to scan it and I make gauges but none of them work. They just show up as --. So I then try to start log screen turns green. I pause it. It goes red. Then I disconnect and I get a error saying.
Error # : 2101. Severity : 1
Error disconnect scanner.
It doesn't log anything and it wont read anything.. The first day i had it tho it worked when I plugged the serial directly into the laptop. But the only thing that worked was reading the gauges it wouldnt log then... My car got hit and took it to the shop and got it back this week and went to connect but it wouldnt.
I connected a keyspan that came with my tuner when i bought it.. I downloaded the proper thing from keyspan's website and got the keyspan all hooked up. I have downloaded the 1.2.4 software off here in the download section. It connects to port 5 and it works fine connecting and what not but I get the error that I stated above when doing the same thing. Also in the bottom left corner it says Update PIDs.
Can anyone help its making me real mad..
Things you should know. The software is all on a windows xp computer. I downloaded the newest framework and the other thing that was needed some windows thing.
Anything and everything would be greatly appreciated.
