Thread: Tuning help
Results 1 to 9 of 9
  1. #1 Tuning help
    Kansas
    Ok well I just recently got a dhp tuner from a member on here. I have 1999 grand prix gt. It has been topswapped and tuned by someone other than me..
    Here is my problems. I get the thing to register on my computer and all goes well. I read the pcm that works fine. Then I go to scan it and I make gauges but none of them work. They just show up as --. So I then try to start log screen turns green. I pause it. It goes red. Then I disconnect and I get a error saying.
    Error # : 2101. Severity : 1
    Error disconnect scanner.
    It doesn't log anything and it wont read anything.. The first day i had it tho it worked when I plugged the serial directly into the laptop. But the only thing that worked was reading the gauges it wouldnt log then... My car got hit and took it to the shop and got it back this week and went to connect but it wouldnt.
    I connected a keyspan that came with my tuner when i bought it.. I downloaded the proper thing from keyspan's website and got the keyspan all hooked up. I have downloaded the 1.2.4 software off here in the download section. It connects to port 5 and it works fine connecting and what not but I get the error that I stated above when doing the same thing. Also in the bottom left corner it says Update PIDs.
    Can anyone help its making me real mad..
    Things you should know. The software is all on a windows xp computer. I downloaded the newest framework and the other thing that was needed some windows thing.
    Anything and everything would be greatly appreciated.
    SOLD 1999 GT Silvermist TS
  2. #2 Re: Tuning help
    Jan 1970
    Maquoketa, Iowa
    I never use the powrtuner scanner. I always use UVScan. Should be available in the same downloads section you got powrtuner from. Either program does not like to be disconnected often, I always need to hit stop log, then disconnect before moving the cable or disconnecting.
    If you are having a problem with connecting, make sure you always use the same port or change it to the correct one your using. I would get fairly comfortable with everything before you go to write the pcm. If you are having problems with disconnecting and such, it may brick the pcm if you go to write to it and have a problem.
  3. #3 Re: Tuning help
    Kansas
    I have never tried to write anything yet. All I have do is read the pcm then tried to scan.. I dont disconnect any wires while scanning but i still get the same error. I leave it all plugged in the whole time. The port is on the right setting and all that is set up right it just gives me the disconnect error and wont show any of the gauges.
  4. #4 Re: Tuning help
    Kansas
    I got it to work.. Had to delete my scan config from before and now it scans reads and logs great.
  5. #5 Re: Tuning help
    Kansas
    Now in my buddys 98 gtp i cant read his.. I can scan it log it but it wont read!! Anyone help?
  6. #6 Re: Tuning help
    Feb 2009
    flintnasty MI
    Is it a supported OSID?
  7. #7 Re: Tuning help
    Outer Space
    Get a copy of UVScan... if you PM me your email, I can send you a copy if needed.
    02 GTP 13.6 @ 100mph - SOLD
  8. #8 Re: Tuning help
    Kansas
    I downloaded it from the tuning site. Thanks though.
    Where do i look to see if its supported?
  9. #9 Re: Tuning help
    Banned
    CT
    This error just started happening to me... I added a gauge and restarted the scan and I get a bunch of dashes, no numbers. Error 2101. anyone know of a fix?
  1. tuning in BC
    By sugaryuk in forum Canada
    Last Post: 12-19-2010, 09:14 PM
  2. Tuning Amp
    By isucyclones3 in forum Audio, Security & Visual Electronics
    Last Post: 02-24-2010, 09:30 PM
  3. Tuning in WI?
    By 03GTP in forum Midwest
    Last Post: 05-26-2009, 09:45 PM
  4. bad tuning and no way of getting better
    By fst in forum PCM Tuning
    Last Post: 08-27-2008, 02:03 PM
