ok do i only need to log in to the hptuner site to download the program??? if so does anyone have the progam because im waiting for the person i bought it off of to give me the login info and i know it will be another day or so till the log on
I could give you the program and usb drivers etc. But you still will require the application key to get it to work with that particular box.
YOu only need the number on the sticker that's on that box and the password. That's all it should be to get on the site as the customer.
ok so no mater what i have to wait for the password... i figured the sticker was the serial number... i was trying to use it today yet i dont see them login on anytime soon
anyone be able to look threw my scan and help me out
sure.
Where'd you find a used one at.
i straightened out the problem with the seller and got everything fixed thank you... and i found it on one of the forums about 2 months ago
So details on car please.
2.188 2.477 2.828 3.227 3.656 4.148 4.648 5.445 6.117 6.805 7.602 8.445 9.414 10.320 11.313 12.305 13.344 14.586 15.828 17.266 18.617 20.023 21.258 22.797 24.352 25.969 27.820 29.906 31.859 34.055 36.289 38.922 41.359 44.055 46.641 49.414 52.898 56.031 59.523 63.727 67.836 71.531 75.742 80.188 84.180 88.461 92.063 97.313 101.703 106.742 111.953 117.273 122.719 128.297 133.938 139.859 145.961 152.297 158.750 165.328 172.000 178.930 186.070 193.453 200.969 208.672 216.633 224.438 231.883 240.070 248.742 257.953 267.188 276.609 286.320 296.328 306.320 316.320 326.320 336.320 346.320
Theres a maf table using your average LTFT's to adjust it then smoothed it a little.
That and resetting your fuel trims might help a little with the 3.9 LTFT at WOT.
Didn't touch 7000+.
ok well i cant stay up because i have to open in the morning... but id appreciate on the explanation of reseting fuel trims...
matt it went from 3.8 to 3.1 ltft but i donno how to reset the fuel trims????
open the scanner.
connect to the vcm.
At the top in the same row that you click the connect to VCM button, just right of centre theres another button.
theres a button which i cannot recall what it looks like, but if you hover your mouse over it, it'll say vcm controls.
open that, then go to the fuel tab, then press reset fuel trims then you can disconnect it again.
ok so far the ltft has been low after i reset the trims... still knocking some though but it has reduced it from what i see...
How low?
Have another log?
i sent you an email with the log... I Have another log i did up to 125 so that one ill email in the morning..
