were should i get my moded pcm from overkill.com or 3800 performance?
overkill 250$ and 3800 is 230$
Ummm, up to you?
I'd get a DHP from 3800 Performance.
And I'm moving this to the correct section as well.
ok i just got the pcm. how do i install it? is it a plug n play? i got it from 3800 performance. i see the other sights haver derections but 3800 dosnt
disconnect battery. use what ever size socket to remove the two plugs on the PCM. install them on the new PCM and then connect bat and enjoy
