Thread: Torque ltft don't seem right
Page 2 of 2 FirstFirst 12
Results 21 to 38 of 38
  1. #21 Re: Torque ltft don't seem right
    I figured out my problem. I put my tb screen in and now it seems pretty normal and now my kr is gone now too.
  2. #22 Re: Torque ltft don't seem right
    Hold foot out
    Shoot self in foot
    Never forget lesson, priceless (specially since you didn't chip a piston yet)
  3. #23 Re: Torque ltft don't seem right
    Feb 2009
    flintnasty MI
    Quote Originally Posted by slick2500 View Post
    What?
    Most 97's typically show stupid amounts of KR randomly, and every 97 reads timing in negative for some reason.
  4. #24 Re: Torque ltft don't seem right
    So -30* is normal for a 97 while cruising its at like 20* or so. Ill double check on my next run.
  5. #25 Re: Torque ltft don't seem right
    Well i checked after i got off work and i still have kr. It must have been the cooler air this morning that made me have none i guess. But at least my ft's are closer now.
  6. #26 Re: Torque ltft don't seem right
    GTX Level Member Juanmiguel's Avatar
    Mexico
    wait, when do you see these knock retards? all the time or just at WOT like in the shift points?
    The KR PID has never worked for us with torque. I even exchanged a couple of emails with the developer and sent him a couple of debug things, but it never worked.
    Check that you've also chosen the correct predefined additional PIDs for GM in the options menu.
    See if you can save some logs and post it so we can see what you're looking at.
  7. #27 Re: Torque ltft don't seem right
    I see it at WOT til i let out. Only 2* today.
  8. #28 Re: Torque ltft don't seem right
    Mine goes up to 9 at wot and while cruising it jumps to 6 so yeah Idk.
  9. #29 Re: Torque ltft don't seem right
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Juanmiguel View Post
    I have specific information on that subject if interested... I have designed a program like torque before.
  10. #30 Re: Torque ltft don't seem right
    Jul 2011
    B-Town, PA
    Torque has had functioning KR abilities since may/june timeframe. there was a specific update to address the issue.
    remove all gauges
    delete all PIDs
    update torque
    reselect PIDs
    readd gauges
    SMGPFC Member # 569 - Mad Monkey Approved!
    New Ride - 2012 CTS-V Coupe 6spd - Black/black, Recaros. Stock for now.
  11. #31 Re: Torque ltft don't seem right
    Slower, Lower Delaware
    Yep, that's the process.
  12. #32 Re: Torque ltft don't seem right
    Mexico
    well have the latest version, so I tried to do the process described above but tried to reainstall the app isntead, but no KR shows up and no other extended PIDs such as the transmission stuff.
    It's ok though I still got the powrtuner, I only use torque to check if the trims are still in range and any SES codes that show up when I'm too lazy to plug the laptop.
  13. #33 Re: Torque ltft don't seem right
    You have to have the paid version of torque the free version doesn't work.
  14. #34 Re: Torque ltft don't seem right
    Mexico
    I have the paid version.
  15. #35 Re: Torque ltft don't seem right
    Jul 2011
    B-Town, PA
    its time to get in touch with the developer then. Ian is great with support. he will help you out any way he can within reason to ensure your functions work properly.
  16. #36 Re: Torque ltft don't seem right
    Uninstall Torque, then delete the files for torque off your SD card, then re-install Torque. That is how I got mine to work.
  17. #37 Re: Torque ltft don't seem right
    Mexico
    Ok it works now. I got the KR dial working now. It's always 0.0 (since my tune is so awesome lol), it used to be -.- before.
    I'm gonna try to go wot for a few seconds next time the ECT is close to 100*C, I'm sure I'll get some KR in there still just to test it.
  18. #38 Re: Torque ltft don't seem right
    Now my ft is +8.6 at WOT I really need a tune.
  1. 16.4 LTFT at idle with E85
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-23-2010, 03:24 PM
  2. LTFT all over
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 10:07 AM
  3. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
  4. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
  5. Increased LTFT's?
    By jims05ss in forum General Tech Discussion
    Last Post: 12-17-2008, 07:49 PM
