Thread: Need some help on MAF tuning
Results 1 to 18 of 18
  1. #1 Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    I'm trying round 2 of tuning my fuel. I'm going by the Russ K method and I've got all of the tables set correctly with wideband reading. All of the tables get readings as well. My beef is that when I flash the PCM for the Russ K method my LTFTs read 0% on all of the tables and but once I flash back to my current tune they are back to all over the place. Can anyone think of what I am doing wrong? I am resetting the LTFTs everytime and unplugging the O2 sensor to put the car in open loop as mentioned in his thread on the HPT forums. I'd like to get this issue figured out as I am borrowing a friends cable and I'm shipping it back to him after this weekend.
    As my tuning file is to large to attach, unless someone sends me their email, it's not getting posted.
    I also went by this method with the same results:
    http://www.grandprixforums.net/start...ers-43997.html
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    BUMP
    77 Morris Garage B
  3. #3 Re: Need some help on MAF tuning
    Donating Users
    South Deerfield, MA
    If the O2 is unplugged and you are in open loop, your ltft's will read zero. The PCM uses the O2 to read the exhaust and set the fuel trims so if it's unplugged, they have to read zero. While in open loop, you need to log your AFR error% and use this to adjust your MAF hz. To do this, you need to log commanded AFR from the PCM vs. actual AFR from the wideband. Log this error% and plot it against MAF hz to know how much to adjust.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  4. #4 Re: Need some help on MAF tuning
    Charles City, IA
    Yeah you need the 02 plugged in thats your issue. When he said to do that he is wideband tuning.
    SMGPFC Two Nipple General
  5. #5 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    So for the percent error would I use this function 100([PID.2811]-[14.7])/[14.7]
    The PID being for the WB though the EGR
    edit:
    Tried that function and it didn't do anything. I modified it to (([PID.2811]-14.7)/14.7)*100 and was getting values at like 80% just driving around so I know that has to be wrong. I understand what I'm trying to do, just don't know how to put it into HPT.
    77 Morris Garage B
  6. #6 Re: Need some help on MAF tuning
    Donating Users
    South Deerfield, MA
    No. This is my calculation from HPTuners for AFR error:
    100*([USER.9004]-[PID.6000])/[PID.6000]
    USER.9004 is my wideband calculation through the A/C pressure switch. Replace USER.9004 with your wideband afr through the egr. PID.6000 is the commanded afr by the pcm. To calculate afr error for maf tuning you need to compare actual afr from the wideband to commanded afr from the pcm. Log this new afr error vs. maf hz and you will know what to change and how much.
  7. #7 Re: Need some help on MAF tuning
    Charles City, IA
    I just use narrow band to get the trims dialed in then once they are locking into zero WOT i wideband tune wot.
  8. #8 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    Got it, I figured it was something in my function.
    77 Morris Garage B
  9. #9 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    I got everything dialed in or so I thought. I was wondering if this is something to worry about or not and if I need to tweak it or not. I got all my part throttle dialed in to 0 LTFTs then did my WOT tuning. I did make sure to reset the fuel trims between each scanning. Right now it's 11.0 AFR with stock 05+ timing.
    Well since it won't accept this scan file I have LTFTs as high as +12 in a couple of cells and as low as -5 in a couple of cells as well. Should I start back over?
    77 Morris Garage B
  10. #10 Re: Need some help on MAF tuning
    Donating Users
    South Deerfield, MA
    Look at the count in those cells that are off. Sometimes you get one or two readings on a cell that happened at a quick change in throttle and the numbers are no good. If you aren't filtering the data, try to keep your throttle transitions smooth to minimize bad numbers.
  11. #11 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    I was probably driving for a good 10 min and scanning the counts were 200+ in the high areas. I was sure to keep the transitions smooth for logging. I'll go out tonight and see where they are after driving all day. Going to bump up the timing a little bit tonight so I'll keep those in mind.
    77 Morris Garage B
  12. #12 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    Did some more scanning and my LTFTs are still high/low with plenty of counts in those cells. Could it be from this temp change that we had this week where I am.? When was doing all the part throttle stuff my LTFTs were 0.
    How would I filter the data?
    77 Morris Garage B
  13. #13 Re: Need some help on MAF tuning
    Feb 2009
    flintnasty MI
    Temp changes have little to no effect on fuel trims. The maf is pretty smart.
    "Tuning your maf" to work in the system that is closed loop using a narrowband... is really just a play on words. As much as you would like to think you are "tuning" your car, you are really just playing games with the narrowband sensor. Any time you are in closed loop, the narrowband sensor is the boss of everything fueling related going on, so any tuning done with the narrowband out, is a complete waste of time. Also trying to tune the narrowband with a wideband is also flawed, as it will always read differently (due to MANY reasons) than a narrowband will.
  14. #14 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    I completely understand that it won't be perfect. Most of the LTFTs are fine, the LTFTs in the low RPMs are high, figured its just where I'm tuning I'm not hitting every cell.
    77 Morris Garage B
  15. #15 Re: Need some help on MAF tuning
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Sandman View Post
    But just remember that you are not tuning anything in the "maf" really, so you really need to be "tuning" the o2 sensor at this point and using the maf to do so.
    I suggest to everyone to just leave a stock maf file in, filter out anything less than 2-4% throttle and hit your injectors by the complete average of every LTFT in a scan.... You can do this in excel quickly and easily... You are always going to have trims, there is really no way around it because the narrowband is a touchy sensor.
    The way I look at the maf.. GM spent millions of dollars to have hitachi develop these sensors, as well as millions to have them write base frequency curves for them.. then they spent millions to have engineers do on car tuning of these sensors to the point that a $30 o2 sensor crammed into an exhaust pipe and a kid scanning it for 20 minutes is probably going backwards.
  16. #16 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    Bumping this
    I'm tunimg again for this L26 swap. Im using the same scanner file that I used months back so i know that it should work. My problem is that the scanner won't read LTFTs at all. Live been scanning the past 3 days and the LTFTs aren't showing up at all, reading 0 across the board. I've been adjusting the MAF table, the WB looks good, and the narrow and readings are locking in at 450 across the board. I want to know that my LTFTs are locking in at 0 but I'm not sure, I want to be sure for WOT tuning. I do have the LTFT setup in the table so it should be reading them but HPT has not shown anything but 0 even starting from the stock MAF table.
    77 Morris Garage B
  17. #17 Re: Need some help on MAF tuning
    Jan 1970
    Maquoketa, Iowa
    If it stays at 450mv, the 02 is dead or you have the tune setup for open loop.
  18. #18 Re: Need some help on MAF tuning
    Jan 2009
    Tallahassee, FL
    Not all the cells are at 450mv, but thats about the average of all of them. 450mv +/- 5 MV I would say.
    77 Morris Garage B
  1. tuning in BC
    By sugaryuk in forum Canada
    Last Post: 12-19-2010, 09:14 PM
  2. Tuning help
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-30-2010, 09:26 AM
  3. bad tuning and no way of getting better
    By fst in forum PCM Tuning
    Last Post: 08-27-2008, 02:03 PM
  4. help ma tuning
    By libster in forum PCM Tuning
    Last Post: 07-21-2008, 03:15 PM
