Thread: ltft on aeroforce gauge
Results 1 to 12 of 12
  1. #1 ltft on aeroforce gauge
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Hey guys, what should my ltft's be with a inlet/outlet i/c ported blower, i/c ported lim, speed daddy headers, 3.4 pulley?
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  2. #2 Re: ltft on aeroforce gauge
    GTX Level Member Juanmiguel's Avatar
    Mexico
    on a stock tune? Probably not +-4%.
  3. #3 Re: ltft on aeroforce gauge
    Bowie, MD
    I actually have an overkill 3.4 tune.
  4. #4 Re: ltft on aeroforce gauge
    Mexico
    I see, well if overkill tune is not adjusted for the ported stuff, I would still guess they would be off that range.
    Sell your scangauge and get a powrtuner =D
  5. #5 Re: ltft on aeroforce gauge
    Texas
    Ltft should be locked in as close to 0 as possible. What is it showing?
    85 Corvette
    01 TA
    03 Z06
  6. #6 Re: ltft on aeroforce gauge
    16.4's
  7. #7 Re: ltft on aeroforce gauge
    Texas
    16.4's
    85 Corvette
    01 TA
    03 Z06
  8. #8 Re: ltft on aeroforce gauge
    Florida
    LTFT's can vary greatly even between stock cars. this is one reason why custom tuning in person or via data logs is so important. a canned tune, even the best canned tune (imo overkill is the best when it comes to canned tunes) a canned tune can not take into account where your base line LTFT's are before the tune. if you could supply a data log to who ever is making your canned tune... this will greatly improve your tune and help to get your trims where they need to be.
    but ideally trims should be zero. +- 5 is good and at WOT should be zero is what most normally tune for. As temp humidity and changes in season will make that 5% change anyway over a year.
  9. #9 Re: ltft on aeroforce gauge
    Feb 2009
    flintnasty MI
    Headers will always screw with O2 readings. You will typically always get overly positive trims at idle and depending on how many exhaust leaks you have, positive trims while crusing.
  10. #10 Re: ltft on aeroforce gauge
    Bowie, MD
    Well it sometimes locks in at 0.0 when cruising and other times around 3.x or -3.x etc etc. Its all over the place. Itried looking to see if any of my vacuum lines where cracked but couldnt find anything. Should i try sealing my headers better?
    Below is a pic of it locked at 0.0 when at a stop light
    And heres a pic of it while i was cruising.
  11. #11 Re: ltft on aeroforce gauge
    Mexico
    +-5% in cruise is fine, they move around all the time, but as long as they are within that range youre good. They should only be stuck in 0 at WOT.
  12. #12 Re: ltft on aeroforce gauge
    Bowie, MD
    oh okay. Guess ill keep scanning.
  1. aeroforce gauge
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2009, 12:01 PM
  2. Aeroforce gauge...
    By duane9586 in forum General Tech Discussion
    Last Post: 07-01-2008, 01:32 PM
