Thread: Please help Performance shift
Results 1 to 8 of 8
sigmapi62 Please help Performance shift 08-14-2011, 07:18 AM
TheOtherNick Re: Please help Performance... 08-14-2011, 09:43 AM
JoRoW99 Re: Please help Performance... 08-14-2011, 11:57 AM
FoSHO99 Re: Please help Performance... 08-14-2011, 02:21 PM
SeanGTP Re: Please help Performance... 08-14-2011, 02:34 PM
sigmapi62 Re: Please help Performance... 08-14-2011, 08:20 PM
SeanGTP Re: Please help Performance... 08-14-2011, 08:39 PM
sigmapi62 Re: Please help Performance... 08-15-2011, 09:09 PM
  1. #1 Please help Performance shift
    Jul 2011
    Sparky land
    Guys,
    First off I have a 98 GT naturally aspirated. I’m trying to get performance shift to work on my car. I followed the write up here on the forum and I cannot get it to work for the life of me. So far a friend of mine and I have used several .bin files from my model year car, took them into tiny tuners made changes, transferred them back into HP tuners and then to my car. The light doesn’t come on and the shift tables never change. I cannot figure out what we are doing wrong. Once again I followed the write up precisely. I am clueless at this point. Is it just my specific PCM that will not allow performance shift or is it something that I am doing incorrectly? Please help guys this is getting frustrating.
    Thanks
  2. #2 Re: Please help Performance shift
    Charles City, IA
    I like to just change the full throttle shift points to what performance shift would be, then you dont have to hit a button.
    SMGPFC Two Nipple General
  3. #3 Re: Please help Performance shift
    Grand Island, Nebraska
    Thats what i would do.
  4. #4 Re: Please help Performance shift
    Jan 1970
    Maquoketa, Iowa
    Well there's only 2 tables in the pcm that really turn it on, so if you can see those tables and changed them, you should be set on that end. Either that or try a different bin file for your GT.
    Next is to double-check the wiring on it, if you feel confident you changed those 2 tables in the pcm, it's time to re-do or have another pair of eyes check your wiring.
  5. #5 Re: Please help Performance shift
    Nov 2008
    Waterloo, Iowa
    If your car didnt come with performance shift, your gauge cluster will probably need a bulb. :P
  6. #6 Re: Please help Performance shift
    Jul 2011
    Sparky land
    What two tables would those be? I figured I would need a light bulb but we couldn't even get the switch to go between the different shift patterns. Could it be that my pcmcia won't accept ps? I read somewhere about putting resistors in the line going to pin 21. Anyone know anything about that?
  7. #7 Re: Please help Performance shift
    Nov 2008
    Waterloo, Iowa
    Your PCM should be fine, but you should be able to put in a PCM out of a 98 GTP which should have the performance shift programmed in. I'd definitely check all your wires and stuff again, make you've got good voltage coming from all of them, etc.
  8. #8 Re: Please help Performance shift
    Jul 2011
    Sparky land
    We tried a file from a 98 gtp and the car woulndt start. HP timers just kept saying paid does not match. Double checked wires again and they all seem to be connected well. You guys have any other ideas? Do u guys have a reccomendatio of someone to contact that coyld help me out?
  1. Performance Shift opt in GTP?
    By Vegas_Matt in forum General Tech Discussion
    Last Post: 07-26-2010, 11:27 AM
  2. Performance shift on used DIC
    By Joe in forum General Tech Discussion
    Last Post: 07-02-2009, 05:08 PM
  3. Performance shift
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 04-12-2009, 11:03 PM
  4. performance shift and TCS
    Last Post: 03-05-2009, 11:30 AM
  5. performance shift WTH?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 07-08-2008, 09:44 PM
