Thread: Diving into tuning [2005 Grand Prix Base]
Results 1 to 5 of 5
  1. #1 Diving into tuning [2005 Grand Prix Base]
    Springfield VA
    Im taking the dive into tuning my car in the next week or two hopefully and wanted to get a couple things cleared up. Ive messed with my PCM very briefly before i took the car off the road for a bit. The extent of the "tune" was copying the Performance shift values into the regular shift tables, and changing my speed governer [which my roomate who has the software thought would be hilarious to cap at 55 ]
    The mod list is minimal, but i will throw them out there anyways
    Open Cone filter
    SLP Loud mouth 3" cat back
    .... yup thats about it for the time being. I am using HPTuners latest beta for software, as well as there Pro interface, although the interface lives in my roomates corvette so i dont get to have the data logging ability for daily driving, although i am looking into getting my own setup, but for the moment using his for free beats 500$+ for my own.
    So the couple questions i have at this particular moment in time are.....
    1) on the stock narrow band what reading is considered safe? and which side is lean/rich [from my research over the last couple weaks it lookes like high is lean and low is rich]
    2)what should i be looking at tuning/modding to make the most of a stock N/A 3800?
    3)Is there anything else to do with the trans at the moment?
    4)is there anything i should not touch? an oddball setting that when changed makes the motor go kaboom, any sort of power limiting stuff, etc. etc.
    From my browsing on the web information on tuning 3800s seems to be kinda scattered, the tuners notebook wiki appears to be plagues with redirects and spam so the only central place ive found is kinda kaputs for the moment.
    I have gleaned that torque mangement is bad and should be disabled, and the method for doing that. I have also seen that maf tuning seems to be more important that SD/VE tuning, granted ive also seen reports of people taking out the maf and running purely on VE tables, but [maybe im wrong] i feel like pure VE tables would hurt mileage.
    As for my goals for tuning im not expecting any miracles here, theres only so much these motors can do without some bigger lungs, but i want to open up the taps on whats avaible, within reason. This car is a daily driver, i take road trips in it, i goto work, i haul people around, it gets a work out no doubt. but having riden in other N/A 3800 cars im confident there is more to be gained. I also feel like i can gain some more MPG's which is ALWAYS a good thing the way gas prices are going these days. So in short i want a tune thats gets better gas mileage with more pep then stock, this doesnt seem out of the question by any means.
    FYI i have a decent amount of tuning experience, ive helped tune a few VW's, a pair of 240sx's and a LT1 swapped 280z, as well as my roomates 2001 Z06. so i grasp the Basic concepts, but havent been able to dig up much info specific to the L26's so anything that you all can divulge would be outstanding!
    Quote Originally Posted by UR LOSN View Post
    all depends on how fast/broke you want to go.
  2. #2 Re: Diving into tuning [2005 Grand Prix Base]
    GTX Level Member Juanmiguel's Avatar
    Mexico
    higher O2s are richer, lower are leaner. I still use a narrow band, but started using commanded AFR for the time being instead of the O2s.
    Given you're basically stock your MAF table should be fine, just check if your LTFTs are in +-3.
    Things you want to look into:
    -More timing (cruise and wot).
    -lower AFR in WOT or PE mode.
    -torque management (disable injector or fuel disabling. Leave spark retard for torque management.)
    -transmission settings for perf shift (shift points and oil pressure)
    -lower temp fan settings along with a colder Tstat
    If I were you, I would take a base canned tune like DHP, Import the stock MAF table and start from there.
  3. #3 Re: Diving into tuning [2005 Grand Prix Base]
    Springfield VA
    The Perf shift settings have already been swapped copied to the regular shift settings, and ive modified the fans to run after the car is off [god send at autocross] but i dont have a colder t stat so ive left them at the stock turn off and on points.
    is there a way to get the car to hold first longer, or better yet not shift itself out? id rather bang off the rev limiter during autox then have the car shift into second, wallow around in the bottom of second, then finally decide it wants to do something and shift back down.
  4. #4 Re: Diving into tuning [2005 Grand Prix Base]
    Kansas
    I would not disable torque management as you will have better chances of ripping out your tranny. And like Juan said, I would start out with a canned tune from either DHP or Overkill and go from there.
  5. #5 Re: Diving into tuning [2005 Grand Prix Base]
    Mexico
    I wouldn't move the perf shift settings to the normal settings, it will damage your transmission faster. I have my normal settings almost stock while the perf settings are very aggressive, but I don't drive in perf mode all the time.
  1. Supercharger for '07 grand prix base model 3.8 L26
    By tino153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2011, 08:14 PM
  2. Cold Air Intake on base grand prix???
    By rashan in forum General Tech Discussion
    Last Post: 09-29-2010, 01:25 PM
  3. 2008 Grand Prix Base Wheels
    By ajaxjblue in forum Tires & Wheels
    Last Post: 10-05-2009, 12:33 PM
  4. Remove back speaker of a 2005 Grand prix base.
    By Lentrave in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2009, 07:32 PM
  5. TC on a 2006 base grand prix
    By nrfitchett4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2009, 06:06 AM
