Thread: Tuning Help
Results 1 to 6 of 6
  1. #1 Re: Tuning Help
    Jun 2011
    Kentucky
    dude yeah I know how boost is measured but the stock cam, valves, heads, are all stock. I ported the intake ports and exhaust ports but that shouldnt change the boost pressure, it will just be more free flowing but its still a sealed unit. I was wondering if anyone out here has ever seen boost drop from a tune with hp tuners?
  2. #2 Re: Tuning Help
    Florida
    YES hp tuners will suck all your boost!
    Please re read what he had to say up there. your mods increase flow. you are correct that durration and lift has not changed, but since you can get more air in because of the lowered restriction you will have lower boost.
    think of it like this. you have the same set of lungs. start running. now take a straw and try to run just breathing thru it! cant go too fast without passing out can ya? your car without the porting is the straw. get it? you havent changed your lungs or your lung muscles at all. just the pipe feeding air to them. same as your car. more flow mods equals less boost. if you are worried check the before and after values of the MAF sensor in your data logs.
    Quote Originally Posted by 05GTPcmpg View Post
  1. Tuning in pa
    By shawn3091 in forum Northeast
    Last Post: 04-26-2011, 12:39 PM
  2. DDM Tuning
    By redlinepontiac in forum The Rant Forum
    Last Post: 03-20-2011, 01:48 PM
  3. VE tuning....not necessary?
    By PacerSS in forum PCM Tuning
    Last Post: 09-21-2010, 08:06 PM
  4. Tuning in WI?
    By 03GTP in forum Midwest
    Last Post: 05-26-2009, 09:45 PM
