Quote Originally Posted by Juanmiguel View Post
Yeah I'm not really going to debate whether the VE table affects the trims or not, in any case you can reach your goal by doing either way. Which I had, my trims are well in the +-3 area, just need to get the ltfts to lock at 0 during WOT.
I'm now moving on with the O2. I'm running very lean at WOT (i don't have a wideband) I'm getting an average of 800 which is way too lean.
Which way is the best to enrich the AFR? I was thinking of just adding to the 7000-11500hz MAF table range by 3% increases.
either that or make sure your commanded or PE afr's are in your target range, or 11.3 or so? if it still doesn't help adjust your maf table.
