I would suggest just reading the bin file and letting the program do the work of extracting the VE table. After you have loaded your scan data, under the file menu, select read bin file. Then find the bin file that was used to make the scan and the program will load it in. It will pull the MAF, VE, and timing tables automagically.
Try that and see if it works.
