Thread: whys everbody hating on ZZP's PCM?
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: whys everbody hating on ZZP's PCM?
    I don't but Bio does with his 4-banger...he's trying to make up for lost powah
  2. #22 Re: whys everbody hating on ZZP's PCM?
    Well...I do too...in the Cobalt.
    But its race powahed.
  3. #23 Re: whys everbody hating on ZZP's PCM?
    SE Level Member Sinister Performance's Avatar
    Fort Wayne, IN
    I'd rather have a street tune than a dyno tune...
    I have to agree. I've tuned several cars, even on different dynos and a common problem that has popped up is these cars always seem to run richer on the dyno than they do on the street. I've seen it so bad where we've tuned an engine to run a rock solid 11.5:1 AFR on the dyno and then took it right out on the street minutes later and watched the AFR jump to 12.5:1!
    Why? Well there always seems to be bad air in the dyno. I don't care how many fans they put in front of your car - unless they have a wind-tunnel set up, you can't duplicate the amount of clean/cool air your car will see while driving down the street in a dyno cell.
    Which probably makes the best/safest (and most legal) place to do a WOT "street" tune on the dragstrip.
    -ryan
  4. #24 Re: whys everbody hating on ZZP's PCM?
    Sep 2012
    Escondido, CA
    I have not blown my engine yet with the ZZP PCM?
    I don't think I know anything about car tuning, so I can't say it's great.
    I think it works better than the stock one on my car.
  5. #25 Re: whys everbody hating on ZZP's PCM?
    Out West
    cuz it sucks.
    Whine with your Cheese?
  6. #26 Re: whys everbody hating on ZZP's PCM?
    Quote Originally Posted by sllsll View Post
    You have a way to scan it?
    If not, this post is moot.
    Also, thanks for bringing this back from the dead...I haven't posted here in nearly two years...score.
    Quote Originally Posted by Sinister Performance View Post
    -ryan
    Only been to the dyno once.
    Afr was the same as street.
    This particular dyno is located right behind the bay door so the fresh air is being pulled from outside and blown into the car.
  8. #28 Re: whys everbody hating on ZZP's PCM?
    Fort Wayne, IN
    Obviously, no two dynos are alike. The one you say your car was run on might have been one of the better ones I've heard of. But, despite this, it is ALWAYS good practice to double-check your WOT AFR's once you leave the dyno tuning session to make sure your engine is getting what it needs once you get it out on the street or wherever you are going to primarily use it. Better to be safe than sorry.
  9. #29 Re: whys everbody hating on ZZP's PCM?
    This.
    Quote of century that I've been trying to get across since I started on this forum that no one can grasp.
    Thank.
    You.
    I agree, just stating it can work out just fine. Agree on strip being a good place to tune.
  11. #31 Re: whys everbody hating on ZZP's PCM?
    Sep 2012
    Escondido, CA
    I got a response! Nice.
    I'm super totally new here, so that's exciting.
    I don't really know how to tune a car, but I got HP Tuners.
    Plugged it in... digging around... changed a few minors thing the way I like it...
    If that's what you mean by scan...
    Quote Originally Posted by blueguy91 View Post
  12. #32 Re: whys everbody hating on ZZP's PCM?
    If you've tweaked your ZZP PCM with HPT...then it is no longer a ZZP tune, lol.
  13. #33 Re: whys everbody hating on ZZP's PCM?
    Sep 2012
    Escondido, CA
    Absolutely true ! Hehehe.
    Well, I did run it for like a week before I messed with it.
    Not bad. And like I said, I could "feel" the different compare to the stock one (no dyno stock vs zzp to compare).
    One thing I noticed right away is they make all fans run ALL the time LOL. I think it's a waste...
  14. #34 Re: whys everbody hating on ZZP's PCM?
    May 2008
    Schuyler, NE
    I've aquired tunes from just about every major company over the years, and have them saved on my laptop. They are all very similar, and they all work very well for stock, or lightly modded cars. They all run rich as hell. They all advance timing. They have all been on a car when the motor or transmission have failed.
    To say that one is better than the other, is like saying that apples are better than oranges.
