Thread: Acceptable KR, stock PCM, L36
Results 1 to 20 of 29
  1. #1 Re: Acceptable KR, stock PCM, L36
    TDCRacing
    Guest
    Quote Originally Posted by IndeedSS View Post
    Although the NB's arent consistant, most have found 920 to 950 the right range. My WB at 11.6:1 AFR was about .920 mV .
    So it's possible you may be running a little lean with o2's in that range
  2. #2 Re: Acceptable KR, stock PCM, L36
    SE Level Member Sinister Drag Designs's Avatar
    With the my 9c1 impala, im seeing 9* of KR at WOT
    my LTFT's are at zero, and fueling seems near perfect.
    im suspecting my unknown mileage injectors are clogged as my IPWs go pretty high . Ive changed a few things on the fuel system and everything was on its last leg and had massive build up and deposits. If this doesnt do it im removing my 300k cat.
    god i cant wait to get rid of this motor and entire fuel system.
    Have you tried running 93 octane to see if its false knock?
  3. #3 Re: Acceptable KR, stock PCM, L36
    Barksdale AFB, LA
    Quote Originally Posted by Sinister Drag Designs View Post
    I still have a tank of 93 in from when I was running the ZZP PCM. Haven't gone back to regular yet (a tank lasts me a while).
    2009 Subaru Impreza WRX STI
  4. #4 Re: Acceptable KR, stock PCM, L36
    TDCRacing
    Guest
    Those are def some good possibilities.
  1. stock stereo
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 02-09-2008, 12:01 PM
  2. Need more input for stock 3.8 NA
    By 03GPScottyd in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-01-2008, 07:19 PM
