Thread: Tuning LTFT's
Results 1 to 3 of 3
Andrew_99GTP Tuning LTFT's 04-10-2008, 05:43 PM
Preotic Re: Tuning LTFT's 04-10-2008, 06:36 PM
Andrew_99GTP Re: Tuning LTFT's 04-10-2008, 08:37 PM
  1. #1 Tuning LTFT's
    GTX Level Member Andrew_99GTP's Avatar
    New Salem, ND
    I am currently in the process of tuning my VE fuel trims. I notice that if I ease into the throttle so that the map kpa slowly increase the trims look pretty good. But if I am at an idle at punch the throttle so the map kpa goes to 70kpa (for and example) the trims are like +6%. Does this matter and why does it happen? If it does matter then how do I tune it out. I am using Eddies table editor, will this tune that out?
    Red 2dr 99 GTP"Old" Z7 t66, A/A IC'd, Custom Heads, 65# Inj, ST2 Cam, Meziere Elec Pump, JP Double Roller(with machined crank gear), Plogs, PLX W/B, Powrtuner SOLD
    "New" 2007 Duramax ccsb with a few mods
  2. #2 Re: Tuning LTFT's
    GT Level Member Preotic's Avatar
    Missoula, MT
    Did you read Jerry's notebook on doing a ve tune? I'm only asking to see that you have set up your bin file correctly to do a ve tune.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  3. #3 Re: Tuning LTFT's
    New Salem, ND
    Yes that is what I am using to guide me in tuning. I wonder if this problem doesn't have anything to do with AE, should I have maybe set that to 100% so that didn't interfere?
  1. Tuning for the turbo
    By TurboKent in forum Turbo
    Last Post: 05-27-2008, 10:33 PM
  2. a little afc 2.2 tuning help?
    By Bio248 in forum PCM Tuning
    Last Post: 02-24-2008, 12:47 PM
  3. Help on Tuning: quicker TCC unlock=less massive KR for downshift
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-20-2008, 09:21 AM
  4. Any Read me's for Tuning?
    By mainecrab in forum PCM Tuning
    Last Post: 02-11-2008, 10:39 PM
