Thread: what limits boost
Results 1 to 20 of 22
  1. #1 what limits boost
    SE Level Member deangtp's Avatar
    Kansas City, MO
    Something in the tune is limiting the boost to only 4 lbs. What is it?
    The story.
    I have a 2000 GTP that went down for a build up. L26 w/ 9.6.5:1 compression, XP cam, 105's, Dbl rlr, P&P Gen V, P&P heads, P&P LIM, headers, exhaust, all the crap. you know. I previously had a DHP 1.0 PCM and thought I didnt want to try and mess with that and not have anything to fall back on so i went to my local junkyard and picked up a spare. This PCM is in my car right now. I have three different files on my comp that i switch things up with and try to figure this out. With the standard DHP 1.0 file with the proper codes removed it runs great. I see 11.3 lbs of boost and everything is good. The base file that we put in to get the car running will not get but 4 lbs of boost. I went through and looked at the 1.0 file and the base file and changed everything to look like the 1.0 file but no dice. Changed the boost ramp rate. I see 16 inches of vacuum. I know the BBV and actuator are good and in working order. no leaks, no cracks. checked a hundred times. Could the VIN number be the root of my problem. IDK. Just throwing it out there. Sorry for the novel
  2. #2 Re: what limits boost
    has to do with the bbv in some way. thats the only thing that limits boost.
  3. #3 Re: what limits boost
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    have you looked at the settings under TQ mgmt dealing with boost?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  4. #4 Re: what limits boost
    Kansas City, MO
    I can take the DHP 1.0 open it up, look at it and make the spare PCM look exactly like it in every way right down to the codes reporting and everything and it still limits the boost to 4 lbs. Is there something about the VIN number or the OSID that needs to be changed for it to read correctly or am I missing something here. Also, with the spare PCM loaded into the PCM I can see several parameters for the transmission and a couple more for the engine that when I have the DHP 1.0 loaded I cannot see. Whats up with that
  5. #5 Re: what limits boost
    GT Level Member Preotic's Avatar
    Missoula, MT
    I'm not sure if you're suppose to be able to see the DHP 1.0. They don't like people knowing their secrets. Perhaps what your seeing is their way of screwing anybody that does. Just a thought, i'm pretty sure the dhp's are locked.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  6. #6 Re: what limits boost
    Kansas City, MO
    The PCM is like 4 years old. before tuners were available, before everything went down with ZZP. I paid 300 bucks for it. I'm not using it to make money or send to people or to screw anyone. it is my PCM. but i got it figured out. thanks
  7. #7 Re: what limits boost
    dont throw that away or anything.
    to run full boost with an l36 pcm just pull out the electrical portion of the bbv and then disconnect the lower vacuum line. thats how i have mine running in order to get full boost. top swapped a while back, never changed to an l67 pcm.
  8. #8 Re: what limits boost
    Kansas City, MO
    Did you know that the little box that has the plug in is the Boost Bypass Valve? The black cylindrical thing with plunger like action and vacuum lines connecting it is called the actuator.
  9. #9 Re: what limits boost
    St Louis MO
    Quote Originally Posted by deangtp View Post
    I thought it was actuator and solenoid and the valve being the blade in the s/c. But the whole thing commonly refered to as the BBV. I need to look it up, since I've ordered these pieces individually within the past year.
    2010 Camaro SS LS3
  10. #10 Re: what limits boost
    Kansas City, MO
    When I first started having these problems, everyone said BBV. So I bought a used one off of a member over on the other forum for 45 bucks. After I put that on and it didnt fix the problem I did some investigating. The BBV and actuator are the same 97-05. If you go to a GM dealership the part numbers go to 98-03. but if you look up an 04 and 05 they are the exact same part number as the 98-03. Yeah i know. It stumped him too.
    Actuator kit.. call # 524/ part #89018120
    supercharger bypass valve..call # 546/ part # 01997244
  11. #11 Re: what limits boost
    St Louis MO
    Good info to have posted here. I looked though all of my purchases from Ed Morad and could not find one referencing the "BBV" parts. There was one receipt but I didn't specify the parts in the Paypal comments section.
    2010 Camaro SS LS3
  12. #12 Re: what limits boost
    if youre truely using an l36 pcm that is your problem. unless you know that already.
    just run it straight up vacuum controlled. disconnect it electrically from the system and disconnect the lower vacuum hose. bam, full boost.
  13. #13 Re: what limits boost
    it doesnt cause a vacuum leak if you disconnect the bottom nipple on the bbv. you just cant still have the rest of your vacuum line still hanging there, it would then end at your fuel pressure regulator.
  1. Stock L36 + Boost =
    By Sinister Performance in forum General Tech Discussion
    Last Post: 02-22-2008, 11:28 PM
  2. any gains in porting the boost bypass passage?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 10:59 AM
  3. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
  4. Picture Limits
    By Abrasive in forum Forum Bugs/Suggestions
    Last Post: 12-17-2007, 01:26 AM
