Thread: Tiny Tuner Public Release
Results 1 to 20 of 20
  1. #1 Re: Tiny Tuner Public Release
    Jul 2010
    North Vancouver
    Thank you, this is the best program ever! Only issue I have, okay so I downloaded a BIN file using a friend's AWESOME (LOVE IT) Tuner Cats OBDII which saves in BIN format, edited the tables I wanted with tiny tuner, but I myself only have HP Tuners, however when I try to load any saved bin with hp tuners I get "failed validation check", so say I load the BIN i got off the pcm it loads fine, but if I load the bin in tiny tuner and save it even without altering any data, automatically HP Tuners wont accept, aparently as soon as there is a checksum anything other than original HP Tuners won't take.
    Did anyone figure a way around it, I edited the file but now I want to load it in hp tuners and flash my PCM.
  2. #2 Re: Tiny Tuner Public Release
    SE Level Member Phantom's Avatar
    Independence KY
    Can you pull the original file off the pcm with Hp tuners?
    Did you say you can load the BIN if it has not been opened in Tinytuner?
  3. #3 Re: Tiny Tuner Public Release
    Jul 2010
    North Vancouver
    Exactly, basically I haven't tried loading the bin after modifying it with tunercat as it's my friends. this is what I have done:
    -Read the bin off the PCM (previously modded with my hptuners)
    -Save bin to laptop
    -Try opening BIN with HP Tuners it opens fine
    -Try opening same bin with Tinytuner, it opens fine
    -Either make a change or don't make a change just resave the same file with or without making any changes using tinytuner.
    -Try opening the edited "saved by tinytuner" version of the same bin and get error "failed validation"
    So in essence, as soon as tinytuner touches the BIN and saves any changes on it, it will not open in ANY hp tuners, I have old version 1.6 and new beta 2.23, it will not accept the tinytuner saved edition of the BIN.
  1. Thinking in public about tire size possibilities
    By DanGTP in forum Tires & Wheels
    Last Post: 07-16-2009, 02:43 AM
  2. PT vs Tiny Tuner; Spark mg/cyl not the same...?
    By agrazela in forum PCM Tuning
    Last Post: 03-07-2009, 05:20 PM
