Thread: Poor times at the track
Results 1 to 8 of 8
  1. #1 Re: Poor times at the track
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by JoshMcMadMac View Post
    I have the Power Enrich Fuel Base vs. ECT set to 12.0 up through 212°F. I guess I will need to do better with the MAF tuning. Did you use the Thingy program at all? I have scans with the same tune with LTFT locking in at -2 instead of 2, but obviously that was not the case at the track.
    Yeah, I usually use the table modifier to see where I'm at on the maf tune and if it's real bad i manually adjust. Run it through that a couple times, sometimes even disable PE by raising the tps pe to 100% throttle and then go through a few more maf tunes, but not getting on it very hard since it will stay at 14.7 afr when disabling PE. I also have the pe enable tps sloped from 40% down to 20%. What I think helped the most on the intercooled regal for tuning was a stock tb/stock maf.
  2. #2 Re: Poor times at the track
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Quote Originally Posted by FoSHO99 View Post
    I am running stock TB and MAF, too.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  1. Reminicing of old times...
    By PonchoDvr4Lfe in forum Off Topic Discussion
    Last Post: 09-14-2009, 09:59 PM
  2. Poor mpg! Help
    By rocafella2032 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2009, 08:15 PM
  3. New times @ ATCO
    By QwikGT in forum Off Topic Discussion
    Last Post: 12-06-2008, 09:15 AM
  4. poor GTP
    By hotshot in forum The Rant Forum
    Last Post: 10-01-2008, 08:08 AM
  5. What times will you be happy with ?
    By Meemperor in forum Off Topic Discussion
    Last Post: 02-17-2008, 04:43 PM
