Thread: Bad MAP??? What should the range be?
Results 1 to 3 of 3
  1. #1 Re: Bad MAP??? What should the range be?
    youre blown? the MAP should hit 100kPa when you start to boost.
  2. #2 Re: Bad MAP??? What should the range be?
    SE Level Member l67fiero's Avatar
    Nebraska
    Yeah, sorry, should have stated that earlier. It is an L67 out of a 01 GTP with vs cam, intercooler (short stack), 3.4 pulley, headers, springs/retainers, ported/polished throttle body, Intense PCM.
    Thanks
    David
  1. plug heat range....
    Last Post: 08-12-2009, 06:30 PM
  2. Engine Temperature Normal Range...
    By Chris in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2009, 08:17 AM
  3. 05 GTP Comp G OEM Remote Start Range
    By Jester331gt in forum General Tech Discussion
    Last Post: 01-04-2009, 08:54 PM
  4. plug heat range question
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2008, 03:03 AM
