Thread: ABS Light after ZZP 1.0?
Results 1 to 8 of 8
  1. #1 ABS Light after ZZP 1.0?
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    Hey guys-
    Someone I know just put a ZZP 1.0 in their 05 Monte, and the Airbag light is now on, after first testdrive with the new PCM... any ideas why that might have happened and will it fix itself?
  2. #2 Re: ABS Light after ZZP 1.0?
    GT Level Member BoostedComp's Avatar
    Youngstown
    the zzp pcm is probably what happened... i have heard nothing but bad from their pcms... id suggest getting it out of there... but hopefully its just a coincidence.
  3. #3 Re: ABS Light after ZZP 1.0?
    GT Level Member JbrownGTP's Avatar
    Colorado
    I have the zzp 1.0 in my car and havent had any problems with it. I think its been in there since november or december idk. Whats some of the problems people are having with them?
  4. #4 Re: ABS Light after ZZP 1.0?
    Then you're one of the few lucky ones...how about chipped pistons for problems. Get rid of that thing...it'll run better with the stock one.
  5. #5 Re: ABS Light after ZZP 1.0?
    Colorado
    I am going to have my car dyno tuned sometime soon do you think it will help the pcm be less likely to destroy my engine?
  6. #6 Re: ABS Light after ZZP 1.0?
    SW Chicago Suburbs
    i think one of the main reasons they got one was it was easier that way to get the codes removed for the o2 sensors, etc...
  7. #7 Re: ABS Light after ZZP 1.0?
    Barksdale AFB, LA
    They loaded the file for a non-Chevy. The Chevy BCM and airbag module only want Chevy bin files on the PCM.
    2009 Subaru Impreza WRX STI
  8. #8 Re: ABS Light after ZZP 1.0?
    Quote Originally Posted by Sabrewings View Post
    Good info man.
    A dyno tune would help if the person knows what they are doing...
  1. Oil light
    By speedemongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2009, 01:21 PM
  2. A/C light always on
    By bjm306 in forum General Tech Discussion
    Last Post: 06-03-2009, 07:45 PM
  3. oil light
    By beto6169 in forum General Tech Discussion
    Last Post: 04-27-2009, 11:10 AM
  4. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
