Thread: Lean LTFT!
Results 1 to 20 of 24
  1. #1 Re: Lean LTFT!
    Milwaukee
    Im unable to tune which is why i have a programmed pcm.
    2003 Galaxy Silver Limited Edition GTP
    Mods: 2.8 MPS | S2IC | XP CAM | GEN V | 65# | E85 | TOGS | N* TB | HPT PRO | Impala Brakes | BUILT TRANS w/3.29 GRS
    23° Timing...12.0 AFR...356 WHP
  2. #2 Re: Lean LTFT!
    TDCRacing
    Guest
    Quote Originally Posted by Lumpo View Post
    Which is why you have the trims like you do. It's very hard to get trims in line without having a custome tune on the car. Ambient temps as little as 10 degrees difference will cause your trims to be off.
  3. #3 Re: Lean LTFT!
    TDCRacing
    Guest
    Quote Originally Posted by TDCRacing View Post
    Again...
  1. Vac leak LTFT?
    By Sabrewings in forum PCM Tuning
    Last Post: 04-15-2009, 05:42 PM
  2. Lean?
    By Deeter in forum PCM Tuning
    Last Post: 09-17-2008, 05:11 PM
  3. Why LTFT, when STFT should be quicker
    By IndeedSS in forum PCM Tuning
    Last Post: 08-26-2008, 08:27 AM
  4. lean condition code
    By TDCRacing in forum PCM Tuning
    Last Post: 05-06-2008, 07:12 PM
  5. 940 WOT o2 is lean?
    By Bio248 in forum PCM Tuning
    Last Post: 03-04-2008, 05:55 PM
