Thread: Lean LTFT!
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Lean LTFT!
    IIRC the '97-'98 MAF's are different than the '99+ MAF's...which is why it is acting up. The deal with the running rich...do you have your lower o2 sensor deleted? That might be why...because '02+ cars need the second o2.
  2. #22 Re: Lean LTFT!
    Milwaukee
    No everything is stock as far as the O2's. After driving it for about 15 min i swapped my old one back and now im back where i started with it haning around 10.1. Something else that is kinda strange with my tune is when i fill up with BP 93 my LTFT hung around 10.1 but i just recently went upnorth and all i could find was BP 92 so i filled up. With the BP 92 my LTFT came down to about 3-5 but everytime i would get on it like passing someone my LTFT drop around -7 to -14 and stay there for about a mile or so before coming back up. Whats the deal with my car?
    2003 Galaxy Silver Limited Edition GTP
    Mods: 2.8 MPS | S2IC | XP CAM | GEN V | 65# | E85 | TOGS | N* TB | HPT PRO | Impala Brakes | BUILT TRANS w/3.29 GRS
    23° Timing...12.0 AFR...356 WHP
  3. #23 Re: Lean LTFT!
    Hmmm...exhaust leak?
  4. #24 Re: Lean LTFT!
    Milwaukee
    I checked multiples of times praying i find one with no luck. I even hooked up a smoke machine and shes air tight. Also why does it make such a dramatic change when i use lower octane gas?
  1. Vac leak LTFT?
    By Sabrewings in forum PCM Tuning
    Last Post: 04-15-2009, 05:42 PM
  2. Lean?
    By Deeter in forum PCM Tuning
    Last Post: 09-17-2008, 05:11 PM
  3. Why LTFT, when STFT should be quicker
    By IndeedSS in forum PCM Tuning
    Last Post: 08-26-2008, 08:27 AM
  4. lean condition code
    By TDCRacing in forum PCM Tuning
    Last Post: 05-06-2008, 07:12 PM
  5. 940 WOT o2 is lean?
    By Bio248 in forum PCM Tuning
    Last Post: 03-04-2008, 05:55 PM
