Thread: what do i need to look out for
Results 1 to 19 of 19
  1. #1 what do i need to look out for
    GT Level Member DWosik13's Avatar
    Detriot,MI
    this may be a dumb question like always lol
    but im getting ready to start scanning my car and im just wondering what besides KR should i look out for so i dont blow my engine cause i had a custom tune done after a cam install and i just wanna make sure everything is all good with the tune
    2002 BLACK GTP ... R.I.P.
    New Car 2009 Cobalt SS
    http://www.cardomain.com/ride/3352208
  2. #2 Re: what do i need to look out for
    Jan 1970
    Maquoketa, Iowa
    02's
    commanded afr
    timing
    PE mode
    STFT
    LTFT
    gear, mph, rpm
  3. #3 Re: what do i need to look out for
    o2s arent super important, but it is nice to see them.
    knock, timing, fuel trims, rpm, MAF, and MAP are what i really look at..
  4. #4 Re: what do i need to look out for
    TDCRacing
    Guest
    02's
    LTFT's
    STFT's
    KR
    Timing
  5. #5 Re: what do i need to look out for
    May 2008
    staten island,NY
    get a wideband!!!!!!!!!!!!!! narrowband FTL
  6. #6 Re: what do i need to look out for
    TDCRacing
    Guest
    Quote Originally Posted by QwikGT View Post
    True. But I got into the low 12's with the narrowband. But that was kind of pushing it.
  7. #7 Re: what do i need to look out for
    May 2008
    staten island,NY
    for the extra 200$ id rather not risk another 3k engine build
  8. #8 Re: what do i need to look out for
    you should be able to tell when youre too lean....it knocks and your o2s are "low".
  9. #9 Re: what do i need to look out for
    Detriot,MI
    and what is a reasonable range for degrees of knock i should be at zero but i just wanna know how much KR is enough to be scared
  10. #10 Re: what do i need to look out for
  11. #11 Re: what do i need to look out for
    Jul 2008
    Germantown, Maryland
    Quote Originally Posted by DWosik13 View Post
    well... technically any knock is not reasonable, unless it's false which you will get, but as you tune you'll start to realize whether it's false knock or not. As for the tuning process you're gonna hit knock every now and then.. and when Josh and I were tuning my car back in october, we had 1 instance where if I even touched the gas pedal I was hitting red...
    ended up pulling over on the highway, haha
    Bio is right, most people keep it 5* as their limit. You're gonna see a lot of little 1* 2* 3* spurts at first. After you slowly dial in your tables it starts to disappear and you'll get your occasional false hits.
  12. #12 Re: what do i need to look out for
    Quote Originally Posted by Quicklynx View Post
    well... technically any knock is not reasonable.
    That is what I go by...Isn't every * of KR like 5-7hp you're losing? Man I'd hate to see 3*-5*
    But that is just me...
  13. #13 Re: what do i need to look out for
    Jul 2008
    Well yes, but I think what DWosik was referring to was how much is "safe" knock that the car can withstand while tuning. Obviously as you continue to tune you want to wipe out the knock.
    Personally I don't go above 3*. If I hit 4* OR 5* I slow down.
    I'm guessing this is your VE tune DWosik?
  14. #14 Re: what do i need to look out for
    Detriot,MI
    ve tune?
    and i have a question i have only a certain amount of time for this so i kind of need a quick answer is v.1 of hp tuner worth getting for $70
  15. #15 Re: what do i need to look out for
    Jul 2008
    if I'm not mistaken, you can just upgrade to the 2.2 version through download off hptuners website. I bought my HPT software which was version 2.2 when I got it so I've never done it. Check HPTuners.com >> Performance At Your Fingertips and see if that is possible. I may be completely wrong! So make sure to check!
    Also you asked what a VE tune is. Since you're just starting out use this.
    Gary's HP Tuners Basic Tuning 101
    Should explain a lot to you and give you a better understanding.
  16. #16 Re: what do i need to look out for
  17. #17 Re: what do i need to look out for
    Jul 2008
    i was seeing up to 10* when i started tuning.
    Ouch... I didn't have it that bad. I occasionally hit above 5* but was very rare.
  18. #18 Re: what do i need to look out for
    SE Level Member RicerKiller's Avatar
    Feb 2009
    Alabama
    at WOT i see about 3*-3.5* sometimes I dont think thats too bad since I have only tuned torque management and the basic stuff, Im starting VE today.
  19. #19 Re: what do i need to look out for
    SE Level Member Sinister Performance's Avatar
    Fort Wayne, IN
    Quote Originally Posted by TDCRacing View Post
    02's
    LTFT's
    STFT's
    KR
    Timing
    Echoing what others have said here, getting a WideBand O2 setup installed would be something you should make a priority. But having said that, if you can't get one, then watch your B1S1 O2 sensor output voltage at WOT. It should stay above 0.890 volts (which according to MY wideband O2 is about 11.8:1 AFR; but remember NBO2's are not very accurate at measuring AFR's much outside of the 14.7:1 threshold).
    I like to see KR stay below 3 deg at WOT.
    I also like to see STFT and LTFT's within a +/- 8% window of operation. The closer to 0%, the better -- but not necessary.
    -ryan
