2007 L32 HP Tuners Software
105 Springs
Double roller timing chain
3.69 final drive
255lph fuel pump
104 plugs
VS cam
Fenderwell Intake
Headers, custom exhaust
3.4 pulley, roughly 9.5psi near 6k rpm.
I have been having a hard time keeping the car in open loop. On my next scan I'm going to set PE to 0% TPS and set the commanded AFR to 14.7. Then I will use the TPS adder to "add" -3.5 to the commanded AFR which will make it 11.2 and command this from 35% up.
I'm commanding 15 degrees of advance. I can post tune files and scans once I figure out how.
I hear some people say you must tune using only the MAF table and others say to tune VE by failing the MAF in the programing. I haven't found a way to completely fail my MAF so I will be adjusting the MAF table with my data from the scans. I have set up a commanded AFR % error table plotted against both the MAF frequency table and one for the VE table as well. Updates will come in the morning after I record on the way to work.
