Thread: VIN change
Results 1 to 3 of 3
  1. #1 VIN change
    SE Level Member fever42's Avatar
    May 2008
    Mobile, Al
    I have a 04 completet L67 with wiring and ecm puting into a 02 will the ser# from l67 be changed to the L36 ser # or does it matter I am in a non inspection state Thanks
  2. #2 Re: VIN change
    04 pcm is different if were talking grand prix's.
    what you want to do if its a getting the engine and tranny swapped is to find a pcm from the same year as your car but a l67. then it will work fine, but if your keeping the na tranny you need tuning for it to not eat the tranny.
  3. #3 Re: VIN change
    I'd assume the engine and computer is from a Impala or Monte Carlo being that it's a 2004. That engine still went all the way to 2005 in those cars and the ParK Ave Ultra.
    The VIN means nothing for getting the vehicle to run. As he said though, the L36 transmission can't be controlled properly if the computer has a stock L67 calibration file in it.
    NA gearing is 3.05 or 3.29 where as the S/C final gearing is a 2.93.
  1. Transmission fluid change, Dealership or Typical Oil Change place?
    By bjornbjorn in forum General Grand Prix Discussion
    Last Post: 09-20-2013, 10:38 PM
  2. Tools/Materials needed for trans fluid change and filter change
    By JDrach in forum General Grand Prix Discussion
    Last Post: 12-10-2012, 07:47 AM
  3. Transmission Fluid - 173K..To change or not to change, that is the question
    By 99XC600 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-01-2012, 10:03 PM
  4. Tranny Fluid - To change or not to change.
    By midrange in forum General Tech Discussion
    Last Post: 02-15-2012, 11:44 AM
  5. SC Nose drive change or pulley change
    By jamster00 in forum General Tech Discussion
    Last Post: 06-04-2009, 03:38 PM
