Thread: Strange KR
Results 1 to 17 of 17
  1. #1 Strange KR
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    I have a strange amount of KR when cruising and some at WOT can anyone look at my datalog and let me know if they see anything?
    Dropbox - maf clean.hpl - Simplify your life
    2004 GTP CompG
    Mods:
    Front P-Log
    Fenderwell Intake
    3in catless downpipe
    104 plugs
    180 stat
    ZZP Tune with maf adjustments and stock ignition tables
    stock pulleys
  2. #2 Re: Strange KR
    Apr 2015
    Columbus, OH
    Your injector duty cycle is over 100% when you are getting knock. And your fuel trims are high. I'd look for a vac leak.
    Top Swapped 01 Imp
  3. #3 Re: Strange KR
    Apr 2015
    Columbus, OH
    But your total trims is like +12 to maybe +20. Not sure why you would be showing over 100 IDC with stock injectors with stock pulley. Can you post your tune? Have you changed injector settings?
    Top Swapped 01 Imp
  4. #4 Re: Strange KR
    It's too rich at full throttle. Anywhere from 10.2 to 10.8 commanded. Without a wideband I don't know how accurate that is to the actual AFR the wideband would show. We can't see custom channels you create using the EGR if that is your method of logging.
    That could explain the high injector duty cycle. Cutting back to 11.0-11.5 could cut 10% from the IDC. Though I do forget if the IDC is accurate on the 2004+ computers, something in the back of mind says to me that that was a topic long ago but I can't put my finger on it.
    I'd like some clarification on what the commanded to actual AFR is like. You should not have a large error between the two.
    The part throttle knock isn't something I could give you a good guess at. Certain harmonics or a weird vibration maybe.
  5. #5 Re: Strange KR
    Apr 2015
    Columbus, OH
    I have the same maths set up, if he's using the egr with an AEM..I haven't looked at many other's logs, so not positive I'm seeing what he's seeing. But I see around 14.7 at cruise, and when he goes WOT he's reading lean. He's commanding 10.7 and wideband is showing 11.7.
    Top Swapped 01 Imp
  6. #6 Re: Strange KR
    Sep 2018
    NC
    My wideband at wot shows around 11.5. I read somewhere that the 2004 computers show the injector duty cycles wrong and I should only look at the pulse width.
  7. #7 Re: Strange KR
    Sep 2018
    NC
  8. #8 Re: Strange KR
    Apr 2015
    Columbus, OH
    Tune looks ok. I assume it was running fine before, and you haven't made any recent changes? I didn't know about the IDC thing, so I got thrown off. Are you hearing or smelling anything odd? I still think you have a nasty vac leak. Your map is high during cruise when you get knock.
    Top Swapped 01 Imp
  9. #9 Re: Strange KR
    I guess I'm always on the mind set that commanded needs to match actual for fueling. That is a huge difference if computer asks for mid 10's but the actual is 11.5ish. That means the MAF calibration has been fudged to get you that value. Because if you were to zero out the rpm adder table and command a solid 11.5 AFR it probably put you in the low to mid 12's based on what we have already seen.
    I'm not saying that's the cause for your knock issues though but it should surely be addressed. It may help with full throttle knock if indeed 11.5-11.7 is not ideal, some cars do like 11.0-11.3ish to keep knock at bay. You're running around 9-10psi in the current weather and that's slightly richer AFR is a good spot to be because as the weather cools the boost pressure may increase by a pound with more dense air.
  10. #10 Re: Strange KR
    Sep 2018
    NC
    No i dont hear or smell anything strange. The only thing I notice is at idle every once in a while I will feel a slight shaking. Not too long ago I smoked the intake to look check for vacuum leaks but i did not see any smoke leaking out.
  11. #11 Re: Strange KR
    Apr 2015
    Columbus, OH
    Yeah man, I noticed his time vs rpm adder is pretty high. It's adding like .850 at 4000 rpm. Is that how zzp tunes work? Just throw fuel at it?
    Top Swapped 01 Imp
  12. #12 Re: Strange KR
    Apr 2015
    Columbus, OH
    Dumb question, but did you smoke test before or after the current issue? Your map is reading like 85kpa at cruise. I'm used to seeing around 45. If it's not a vac leak then I don't know. But I'm on an 01 pcm, so I obviously don't k ow all the 04 quirks.
    Top Swapped 01 Imp
  13. #13 Re: Strange KR
    Sep 2018
    NC
    I smoked the intake because i was getting a p0300 code that would be repeatedly set at idle with my fuel trims being high at idle but decreasing with the rise of rpm. The counts of misfires where all on cyl 3 and did not change when swapping coils. Just simply swapping spark plugs from another cylinder caused the misfires to stop and it also did not follow the plug which I found strange. I also preformed in cylinder pressure testings and also looked at pressure wave forms of intake vacuum while cranking and all looked to be perfect. I just recently replaced all 6 spark plugs gaped at 0.055" and cleaned the MAF to see no change. I did have these weird blips of kr while cruising and at WOT before the testing I performed and I still do currently.
  14. #14 Re: Strange KR
    Apr 2015
    Columbus, OH
    If I were you I'd compare a known good scan to your current scan. That map is high to me. Unless maybe your cammed. Idk
    Top Swapped 01 Imp
  15. #15 Re: Strange KR
    Sep 2018
    NC
    Where would I be able to find a known good scan of an 04 stock pulley gtp?
  16. #16 Re: Strange KR
    Apr 2015
    Columbus, OH
    I was talking about scans of your own car. You don't have any saved when your car was running good?
    Top Swapped 01 Imp
  17. #17 Re: Strange KR
    Sep 2018
    NC
    I might ive had this problem for some time now.
  1. strange gtp in the jy
    By l67ss in forum General Grand Prix Discussion
    Last Post: 07-16-2014, 07:47 PM
  2. Strange Fog
    By goochman in forum General Grand Prix Discussion
    Last Post: 02-21-2014, 09:03 PM
  3. strange shaking
    By occrocks in forum General Tech Discussion
    Last Post: 12-18-2010, 01:19 PM
  4. For some strange reason
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 06-12-2010, 07:53 PM
  5. very strange problem.
    By maniakmyke in forum General Tech Discussion
    Last Post: 03-04-2010, 04:45 AM
