Thread: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
Results 1 to 20 of 24
  1. #1 AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Mar 2017
    NC
    I checked with AVT, and I was told that DHP contacted them and asked not to program the devices to look like they've been registered in DHP. From what I understand, there was a workaround to use these AVT interfaces and to get them registered properly before AVT started to program the units to appear registered. Does anyone know what that workaround was?
  2. #2 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    as far as i know, avt guy there is the maker and seller of the original dhp boxes. if you were to open up a old dhp its stamped AVT-what ever # it is.
    so there was never a before he started to make em, he always has.
  3. #3 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Mar 2017
    NC
    From what I understand, though AVT always made them, the adapter wouldn't be activated until it was registered through the software. For some time, AVT started to flash the device to appear to be activated without the need to do it through DHP software. Now, he can't sell them that way and a new adapter will have to be activated as they had to be before.
  4. #4 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    GTP Level Member
    Jun 2016
    Cleveland ohio
    He will not make them anymore. The owner of DHP told him to stop.
  5. #5 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Mar 2017
    NC
    Quote Originally Posted by rickisrad View Post
    He still makes the interface and will still sell it, but he just can't flash it to look like it's registered by DHP. I learned of this because I got a quote, and was told what to expect with the purchase.
  6. #6 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Jan 2017
    xx
    Glad I got mine last year.. What is that initial activation step in DHP do the first time you run it, then?
  7. #7 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Mar 2017
    NC
    Quote Originally Posted by digitaloutsider View Post
    I know that the instructions that DHP provided say to connect to the car and laptop, and opening the software will start the activation process. I just don't know if it still works like it used to. AVT told me that someone recently purchased one. Hopefully I can get some info on if it worked for that person.
  8. #8 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Jan 2017
    xx
    I also wonder why Charles would care all of a sudden. It's not like you can buy DHP anymore.
  9. #9 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Jan 2017
    xx
    My guess is that there's some DHP-specific code it looks for when registering the box. Otherwise, I don't think this would make any difference.
  10. #10 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Mar 2017
    NC
    confirmed that the device is sold the same way it was when they sold to DHP originally.
  11. #11 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    so your saying they still work as they should?
  12. #12 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Jan 2017
    xx
    So nothing actually changed?
  13. #13 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Mar 2017
    NC
    I guess I'm doing a terrible job of explaining it. Here's what AVT sent me:
    That's an interesting question.
    Let me tell you a little history about this and in the process I'll
    (hopefully) come up with an answer. My memory about the exact order of events and who was involved might be wrong here and there, but the general discussion is correct.
    I designed, built, and sold to DHP several models of interfaces. They were OEM boxes, just plain black boxes with my hardware inside. (I still sell that hardware to my industrial customers.) For unknown reasons, the two guys that ran DHP quit buying my stuff and, from my perspective, disappeared.
    Then (a few years ago ??), a DHP user contacted me about fixing his interface. He told me that, apparently, DHP had gone out of business (which confirmed what I thought, as they stopped buying hardware from me). He eventually sent me several to repair.
    During all of that, he (the user) told me that he figured out a way to program some information into the interface so that the old DHP software would work. He told me how to do it, and I replicated what he had done so that I could fix his hardware. He then told me that if another DHP user bought my hardware I could use the same procedure so that user could then use the hardware with their software. So, I did that for a few folks where I had to repair their interface or, in one case, where they had lost their interface during a move; and maybe a few others.
    Plus, as far as I knew, DHP was gone; so I didn't see any harm in it.
    I guess someone posted some information about what I could do on a forum (somewhere). Early this year, out of the blue, one of the principle owners of DHP contacts me and tells me that I'm violating his copyright (or some such thing) by bypassing his security features of his software.
    He asked (sternly, but politely) that I stop doing that. I thought about it for a while and came to the conclusion that it might be a bit legally foggy as to what I was doing was wrong, but none-the-less, the prudent course of action (and not wanting to burn any bridges, should he want to resume a business relationship) it was best that I agree to stop.
    Hence, when someone, such as yourself, writes to buy an interface that is compatible with the old DHP software, I have to figure out a way to say that it 'will' and 'will not' work with that software. It 'will'
    because the hardware and software will work, but it 'will not' if the software is expecting the hardware to have some kind of information stored in it - that I don't normally put there (that DHP apparently used to put there).
    One more thing. I do not work on cars. I do not have, and have never even seen the DHP software. I have no idea how it works, what it does with a car, and no idea how it handshakes with the hardware.
  14. #14 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Mar 2017
    NC
    Can anyone tell me if the AVT-852 bought directly from AVT needed to be registered in DHP (like the original DHP adapter did), or would it fire right up in DHP with no registration needed?
  15. #15 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Quote Originally Posted by LMNOParis View Post
    back in the day dhp was like hpt, you bought the interface, then bought credits, they sent you a bin for your year car. some how it all became unlocked so you can just hook up and tune about any w body now. with no credits or registering with dhp, just works.
    the term registering the cable is when you sync the laptop, car and interface together for the first time. once its all happy reading back and fourth its registered. and you can read write and edit bins.
  16. #16 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Jan 2017
    xx
    I bought an AVT-852 last year, and it registers in DHP just fine (as it does when you run DHP for the first time after an install), BUT I told him specifically I would be using it with DHP software, so if there is some workaround that is required, I have it. The only way we'll know for sure is if someone buys an AVT box now.
    I have no idea what that registration process does. I'm just really puzzled about this whole thing. I even posted on the DHP/HPTuners Facebook group and got help from Charles directly when I was having issues getting the software to run. I even sent him over a BIN file for my Regal that was, for some reason, unsupported in DHP. I guess all good things come to an end. I suppose I should be glad there was even an alternative in the first place from the clunky Keyspan adapters and paying $Texas for HPT.
    Edit: I also don't know if we should really post that direct communication you had with him. Mike is a really stand-up guy, and I asked him a few questions about how the AVT hardware interfaces with the car, and he was more than happy to write me back with tons of documentation and information. I'd hate to get him in trouble with someone or cause a "bridge to be burned" if Charles ever decides to sell DHP again.
  17. #17 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Mar 2017
    NC
    I asked him first if I can start telling the story. I didn't want to just cause nonsense for him. I'm bringing this all up because I'm hoping we can still have AVT as an option instead of being stuck with HPT, and Mike wants to keep selling us a good product.
  18. #18 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    hes double talking lol is that a yes or no?
  19. #19 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    Antioch, IL
    I blame GPF for the word getting out, also scotty
    2009 Challenger SRT8
    Expert at being gay.
  20. #20 Re: AVT-852 for DHP Powrtuner can't be purchased pre-registered anymore
    snowflake made it all public here first.
  1. finally registered, but looking to sell 97 GTP
    By taplai0 in forum Introductions/Noob Questions
    Last Post: 07-29-2016, 08:58 PM
  2. Can't get my DHP registered
    By jdmgtp in forum PCM Tuning
    Last Post: 09-03-2014, 05:37 AM
  3. Just Registered ! From INdiana
    By Logan in forum Introductions/Noob Questions
    Last Post: 09-10-2010, 11:45 AM
  4. Finally registered.. red gtp
    By Perry125 in forum Introductions/Noob Questions
    Last Post: 08-22-2009, 09:58 AM
  5. finally registered....
    By kfog in forum Introductions/Noob Questions
    Last Post: 06-20-2009, 10:44 AM
