Thread: knock issues???
Results 1 to 20 of 33
  1. #1 knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    hi all,
    I am doing some scanning and am having some issues with knock. Mostly between the 4000-5200 rpm range and .92g cylinder airmass. the knock average is 9 for the 4k/.92 and 4 for the others. The high Octane/spark timing is already down to 10 in those cells. The o2 Readings at the 9000 hz up range from 910-945. I am not sure what to adjust from here. The trims are all within 5%. It drives fine and has good power. Any suggestions on where to adjust or look for the issue?
    I have a rollmaster timing chain, 90# springs, 1.85 roller rockers so I dont think valve float is an issue.
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: knock issues???
    so your seeing 9 degrees kr?
    how many miles are on your blower? ive seen them cause kr when you get bad bearings.
    have a wb? and whats your timing set to wot?
  3. #3 Re: knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yep 9 degrees KR. The blower has about 160k on it. I will probably have to look into getting the blower rebuilt. I don’t have the presses to do it myself. Unfortunately I do not have a WB. I really need to get one sooner than later!!
  4. #4 Re: knock issues???
    take the blower belt off, then go beat on it, see if the kr went away with no blower.
  5. #5 Re: knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Ok I will try to get it off before the drive home from work.
  6. #6 Re: knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Well I pulled the belt and scanned for knock on the way home. Besides the POS HPT app freezing I did not see a blip of knock. I was not able to get to the cells that was showing before but was able to get a couple of wot runs and no knock what so ever. Looks like I am going to have to buy a rebuild kit and a press from Harbor freight.
  7. #7 Re: knock issues???
    lets not get crazy yet on a new blower.
    whats your timing set to wot? it might be to high. simple fix.
  8. #8 Re: knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I’m not really sure where to find that. I’m seeing the high/low octane advance and the Max Torque Timing. The High Octane is where I adjusted the timing at in HPT. In that the timing at .92g airmass 4K-5200 rpm is 10 degrees. 5600-6400 rpm it is 15 degrees.
  9. #9 Re: knock issues???
    if you have the stock file still from your saved first read, copy that back over. im willing to bet you have the timing adders still on and your getting more timing then what you see in the timing table.
    in the scanner scan for timing advance. if you figure out how to put it in a graph you'll see the timing over all much better.
  10. #10 Re: knock issues???
    Kemmerer, Wyoming
    maybe it's as simple as a pulley too small
  11. #11 Re: knock issues???
    3.4 on a gen 5 is a bit much, will likely need to run less then stock timing wot.
  12. #12 Re: knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I do have the advance timing charted. It is reading about 16 degrees in those few cells. That is about what they were set at. The base correction added for fuel is adding but the IAT and ECT are zeroed out.
  13. #13 Re: knock issues???
    Kemmerer, Wyoming
    that just means it's not adding timing advance at full throttle. you need to pulley up, I would try a 3.6. 9* of kr will chip a piston sooner than later.
  14. #14 Re: knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah you are probably right on that. May be a combination of that and the sc age. I need to get a 3.5 pulley to try out. I want one of Ed’s intercoolers but that is probably 5 months away.
  15. #15 Re: knock issues???
    or drop the timing by 4 degrees.
  16. #16 Re: knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I will drop the timing some more and scan some more in the morning.
    Have either of you rebuilt a supercharger?
  17. #17 Re: knock issues???
    little story, my cars a kr monster too, well used to be. a aem meth injection kit is cheaper then a ic. and likely do more.
    i have a l36 bottom end, gen 3 blower, diy ported heads, 1.95 rockers, and a fsic. i was running a 3.2 with all that, and like 14 degrees wot timing.
    added a meth kit, got it to take 21º wot and running a 2.8 kr free.
    im willing to bet you could run a 3.0 with meth and more timing.
  18. #18 Re: knock issues???
    knock issues??? Attached Images
  19. #19 Re: knock issues???
    Kemmerer, Wyoming
    I doubt it's the blower itself, just the fact that there is too much boost. you would be seeing kr at idle too if the blower was bad.
  20. #20 Re: knock issues???
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I think that may be the route to go with the meth kit. I have access to methanol at work.
    Marshal, very true. I would probably see/hear more
  1. Top Swap and S2IC Knock KR issues
    By rell2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-11-2012, 01:43 PM
  2. Replies: 19
    Last Post: 04-10-2012, 01:06 AM
  3. Got some knock issues I'm not to sure about
    By Sandman in forum PCM Tuning
    Last Post: 01-21-2012, 08:49 AM
  4. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  5. Bad EGR = knock?
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-31-2008, 07:13 PM
