Thread: Tune out P0303????
Results 1 to 10 of 10
  1. #1 Tune out P0303????
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Someone I know is trying to tune out code P0303 misfire cylinder 3. It is a guys from work 2004 GT. He is having issues passing emission testing since the light is on. It has(d) the random misfire and knock sensor circuit codes that were able to be deleted. For some reason I can not find the specific cylinder codes to delete (disable ses light). Is there a way to do this?? Thanks
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Tune out P0303????
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    90% sure there's a way to do it with hp tuners, but why not just fix the misfire...?
  3. #3 Re: Tune out P0303????
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I have HPT but do not see that code In the list. Weird. He’s not going to fix it because he’s a cheap ass. I was going to throw one of my spare injectors in there to see if it helped him but my supercharged injectors are different from his NA. Someone put plugs and wires in it before he bought it but cross threaded the #3 plug. I unplugged the #3 injector and no change in idle. So I am thinking it is an injector. Tuning the codes out is temporary just to get his plates and buy time for him to fix it.
  4. #4 Re: Tune out P0303????
    GT Level Member mguzzo's Avatar
    Buffalo NY
    that diagnostic code isn't visible in DHP either
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: Tune out P0303????
    The Boss Iceman6669's Avatar
    Jun 2011
    If you tune out the P0300 code, sometimes it also disabled all the misfire codes as well.
    2011 F-150 Yote powered
  6. #6 Re: Tune out P0303????
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah I tuned out the P0300 and for some reason that and the P0303 was still showing as active codes in the HPT scanner. It didn’t show on the echeck code checker though. So the car “passed” the test.
  7. #7 Re: Tune out P0303????
    Buffalo NY
    as I like to say, "if it don't set the light, it must be all right."
  8. #8 Re: Tune out P0303????
    I do know that you can turn off P0300 and all the cylinders will still show up.
    I just pulled up HPT and was able to turn P0300 to no report as well as P0301-06 for each cylinder on an 02. Looked at 04 and it's sure as heck missing. That's odd.
  9. #9 Re: Tune out P0303????
    Buffalo NY
    wonder if the diagnostic code table could be copied from a 98-02 file into an 04 file?
  10. #10 Re: Tune out P0303????
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I’ll email HPT to find out why it’s not in there for the 04+. It should be if there is a specific code. Weird.
  1. P0203 and P0303 help??
    By MattGTP04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2015, 11:23 AM
  2. P0303 Code. Help!!!! Misfire!!!
    By cdubb79 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-05-2013, 11:56 PM
  3. P0303 missfire
    By BigGeorgesGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2012, 04:27 PM
  4. Code P0303, and p0300
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2009, 09:08 AM
  5. P0303 - Cylinder #3 Misife ...
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-04-2008, 01:23 PM
