Quote Originally Posted by Swiggles View Post
Have you tried plugging in the evap components to see if it shuts the light off? I always left the evap stuff plugged in and just set everything to now reporting.
The reason it's not connected is because this is a 1998 PCM swap into an older car. The 98+ evap system is different than the older stuff and incompatible so when I rewired the PCM connectors I left all the evap wires out.
I can give those pins 12v through current limiting resistors to simulate the solenoids being present and trick the computer.
...but I should be able to turn off these codes with software and I'd like to solve it that way if I can.
