Thread: DTC codes won't disable
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: DTC codes won't disable
    those codes were low voltage or some bs. plugged in or not, should not set the light. my egr, rear o2 and purge solenoid are 100% gone, plugs just sit there doing nothing.
  2. #22 Re: DTC codes won't disable
    May 2016
    Austin, TX
    Quote Originally Posted by Swiggles View Post
    Have you tried plugging in the evap components to see if it shuts the light off? I always left the evap stuff plugged in and just set everything to now reporting.
    The reason it's not connected is because this is a 1998 PCM swap into an older car. The 98+ evap system is different than the older stuff and incompatible so when I rewired the PCM connectors I left all the evap wires out.
    I can give those pins 12v through current limiting resistors to simulate the solenoids being present and trick the computer.
    ...but I should be able to turn off these codes with software and I'd like to solve it that way if I can.
  3. #23 Re: DTC codes won't disable
    May 2016
    Austin, TX
    some pcm's cross over, i got a 01 pcm in my 98 regal. with a 98 bin of course. you need the year of your car bin for it to run right.
    all you can do is try, if it takes it will just take, if its not gonna work you get a warning that is not comparable.
    theres a pcm compatibility list in that drop box folder. shows the cross over part #'s.
    I'll stick with the 98 bin file then. I have three PCM's total for this car and they are all the same part # and are from 1998 vehicles.
    I guess I'll get to work on copying everything over to that newer osid bin file and see what happens.
  4. #24 Re: DTC codes won't disable
    plug the new one in and flash away.
  5. #25 Re: DTC codes won't disable
    May 2016
    Austin, TX
    I copied everything over to the newest osid bin file this morning and programmed the existing PCM with it.
    When I first started the engine I actually got more of the P16xx improper voltage codes for other pins that's I didn't connect, but after going back and and setting them to 3 and doing a partial write, they all went away. This osid seems to actually respond to the changes I make so I think the problem is solved.
  6. #26 Re: DTC codes won't disable
    sounds good. if you have a hand held code scanner, check for "im readyness" evap should be ready with out any drive cycles.
  7. #27 Re: DTC codes won't disable
    Mar 2017
    Internet
    Oddly I remember someone having trouble with EGR codes/emissions not going green. hahahaha
  8. #28 Re: DTC codes won't disable
    Quote Originally Posted by BillBooost37 View Post
    it was evap......only thing i need to wait to be "ready" is the o2 sensor.
  1. DoD disable...but why?
    By Altairus in forum 5.3L V8 (LS4)
    Last Post: 10-16-2019, 09:11 PM
  2. Disable DRL on 04+?
    By arlenok in forum General Tech Discussion
    Last Post: 05-02-2014, 06:36 PM
  3. DOD disable
    By gtx3800 in forum 5.3L V8 (LS4)
    Last Post: 06-21-2013, 01:12 PM
  4. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  5. DRL Disable!!!!
    By 1SICKGP in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-29-2010, 12:16 PM
