When I look at my log file I can see a correlation between the wideband and ltft. Im going lean at idle in closed loop. For instance my wideband will be at 16to18 when the ltft is -3 to-7 and when its is near 0 the afr goes close to stoich. When cruising the afr is fine. Also why would the afr be commanding 10.3 in pe when the pe tables are set to 11.7?
This 3800 is in a 5speed fiero with xp cam, 3.4, slp headers open downpipe
