Thread: E85 sensor on 2001 GTP with HP Tuners
Results 1 to 3 of 3
  1. #1 E85 sensor on 2001 GTP with HP Tuners
    Kemmerer, Wyoming
    I have a 2001 Grand Prix GTP. I also have overkill's E85 sensor kit designed for the 2008 GXP. I know the tune on the 2001 can't adjust on the fly for E85, but I have an HP Tuner, and if I can see what percentage of ethanol is in the fuel with the HP Tuner, I can make a rough correction. Would I wire in the sensor the same, except use the wire that would go to the pcm and hook it up to the HP tuner input?
  2. #2 Re: E85 sensor on 2001 GTP with HP Tuners
    Quincy, Mass
    That sounds right to since the pcm wouldn't know what the signal was. You'll have to make a custom pid for it in hpt. I have never used or tuned e85 but logically that would make sense.
    No more GP 04 Impala SS Indy:
  3. #3 Re: E85 sensor on 2001 GTP with HP Tuners
    May 2008
    Schuyler, NE
    Hpt has 0-5v inputs. So as long as the sensor output is 0-5 volts, it will work.
  1. Replies: 7
    Last Post: 01-31-2015, 07:12 PM
  2. Replies: 1
    Last Post: 02-07-2013, 02:11 PM
  3. 2001 Grand Prix A/C Pressure Sensor
    By Bartbk02 in forum General Tech Discussion
    Last Post: 07-07-2009, 10:34 PM
