Thread: belt slip or?
Results 1 to 7 of 7
  1. #1 belt slip or?
    Kemmerer, Wyoming
    I have a history of over complicating things, and i was wondering, am I over complicating things and thinking I have belt slip up top because it seems like more air flow would have more boost.
    https://drive.google.com/file/d/0B6K...ew?usp=sharing
  2. #2 Re: belt slip or?
    May 2008
    Schuyler, NE
    Belt slip usually spikes. Yours is a nice smooth curve. That actually looks fairly normal to me.
  3. #3 Re: belt slip or?
    Kemmerer, Wyoming
    thanks for your input.
  4. #4 Re: belt slip or?
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    The obvious solution. (no, not compressor surge)
  5. #5 Re: belt slip or?
    Kemmerer, Wyoming
    the screws were loose on the mps hub
  6. #6 Re: belt slip or?
    May 2016
    MN
    Did that fix it? Seems like an odd symptom. Guess I'll be mindful of it later on.
  7. #7 Re: belt slip or?
    Kemmerer, Wyoming
    yep, that fixed it. one screw was 2 rotations away from flying off, so if the pulley wasn't on the hub like it should have been, there would have been play, resulting in belt slip. since then my boost amount has gone up to 10.7 max psi.
  1. Hards GTP on 3.0 but with no belt slip this time!!!
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-30-2014, 07:32 PM
  2. Belt slip
    By TTalon in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2011, 02:30 AM
  3. Belt Slip
    By swat0712 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2010, 09:21 PM
  4. 3.4 is on! belt slip solved still knockin :)
    Last Post: 08-08-2009, 03:31 AM
  5. Accessory Belt Slip
    By Damojo2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-28-2008, 02:20 PM
