Thread: afr spark ?
Results 1 to 8 of 8
  1. #1 afr spark ?
    Nov 2016
    sheridan
    been working on the tune in my car
    from what scotty has told me the actual timing is always 5* higher than what the good fuel spark table says. my car seems to be 8* over that from watching commanded spark
    i see in the afr spark setting that it adds 7.99* of timing if its 9.7 commanded afr is that where the 8* extra im seeing is coming from ?
    can i set that to 5* so make setting my timing simple ? so it will be 5* across the board
  2. #2 Re: afr spark ?
    Yes, that is where it comes from. It vaires from like 3º to 8º depending on commanded AFR. I'd have to screen shot it with HPT to show it though.
    You can remove the AFR spark adder and set the commanding timing to whatever number you really want to.
    It's what did with HP Tuners.
  3. #3 Re: afr spark ?
    Nov 2016
    sheridan
    im just gonna take the 7.99* at 9.7 to 5* so it quits screwing me up..
    what table sets the wot commanded fueling
  4. #4 Re: afr spark ?
    In HP Tuners it's Base AFR vs ECT and then it adds fuel with a table called ADD vs RPM.
    So it's 12.40 + the add vs rpm table that brings in more fuel depending on rpm and how long you are in PE (power enrichment). Most just zero out the add vs rpm table and make the commanded AFR a straight 11.5 or whatever they choose.
    I don't have DHP so I forget what they might call them exactly.
  5. #5 Re: afr spark ?
    pretty sure you need to turn that adder off with tiny tuner. dont think dhp cant turn it off.
  6. #6 Re: afr spark ?
    Nov 2016
    sheridan
    i set the 9.7 afr to 5* just to make things simple
  7. #7 Re: afr spark ?
    Nov 2016
    sheridan
    i also noticed that tiny tuner hoes to 920mg/sec where dhp stops at 680mg/sec will that matter at all in the timing
  8. #8 Re: afr spark ?
    Sep 2015
    flint
    DHP's database displays the wrong G/s on the timing tables for GTP files, but it is just in display only, its really 920 even if it says 680.
    Doesnt run 9s
  1. 98 Gtp No Spark
    By GreenGTP91 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2013, 10:35 AM
  2. Need Help With No Spark!
    By wa04compg in forum General Tech Discussion
    Last Post: 04-01-2012, 03:52 PM
  3. No spark HELP!!!
    By Machzzzz1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2010, 12:30 PM
  4. 72 gp sj no spark
    By rayzo63 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:40 PM
  5. no spark
    By faboskay57 in forum General Tech Discussion
    Last Post: 07-10-2008, 07:41 AM
