Is it possible to combine gauge readings into one gauge? I'm want to combine inHg and psi for a vac/boost gauge.
What I want to combine are these:
Into something like this:
Sent from my iPhone using Tapatalk Pro
Not that I know of because one "gauge" can only have 2 pids/channels it's taking from and not 4 like that would require.
I gave up on making one a long time ago and haven't looked into since. I just watch MAP kpa to determine boost levels. After a while is easy to remember what each kpa number means in boost.
I gave up trying to read boost like 5fdp a while back as well and use the same method of converting map kpa into boost. I use this website as a referance:
http://forums.holley.com/showthread....SI-Equivalents
