I would think mid teens would be a good spot to start as you work out any kinks and get things running good. You wouldn't want to slap it with 20+ degrees of timing straight away and have some sort of failure.
Then watch knock from there, no knock = raise the timing a degree at a time. Then once you see knock, back it off 2 degrees and it should be plenty safe.
