Quote Originally Posted by timboku View Post
I work in Joliet and can remove the codes so you can pass emissions, but you have a different issue....did you check make sure your wire harness for 02 isn't Burnet or grounding out? What brand 02 sensor you buy? Did you check fuse 21 under hood make sure that's not blown? Did you put SD headers on? Did you bang tunnel so 02 sensor doesn't hit the tunnel?
Sent from my SM-N910V using Tapatalk
Nope I went through and checked for burnt wiring and didn't see anything. I made sure to zip tie everything away from the exhaust. I do have the zzp o2 extension and a stock o2 sensor that I actually purchased from Reptile about a year ago. I do I have SD headers and I have a couple of cm of clearance. When I replaced the dog bone bushings with urethane I made sure to rock the engine back and fourth multiple times and from what I could tell there was no contact with the firewall.
