Thread: Can anyone here tune some codes out?
Results 1 to 10 of 10
  1. #1 Can anyone here tune some codes out?
    May 2015
    Joliet, Illinois 60436
    Hello, I have a problem. Ever since I've installed headers I have both codes P0135 and P1133. Nothing I do has made these codes go away. I got a new upstream o2 I got a high flow cat and these codes won't go away and emissions are coming up in November. So can anyone near Joliet,IL 60436 tune these codes out for me? I'm willing to ship my pcm out too.
  2. #2 Re: Can anyone here tune some codes out?
    Omaha, NE
    Unless you have some extensive mod list, you shouldn't NEED an in car tune. I would just do mail order.
    PM Reptile, he is only doing a few more tunes before he retires from tuning.
    Or order one from Will:
    http://www.getoverkilled.ca/3800sc.html
  3. #3 Re: Can anyone here tune some codes out?
    you cant delete those codes, check your o2 harness or inspect the connections if you made your own extension harness. if the o2 is hitting the firewall good chance you killed it from hitting the f/w.
  4. #4 Re: Can anyone here tune some codes out?
    Omaha, NE
    I didn't think to check which bank those were for. Bank 1 Sensor 1 can be deleted if you run a speed density tune, but... That's unnecessary. And more of a pain to tune.
    Are you using an OEM o2 sensor or an aftermarket replacement?
  5. #5 Re: Can anyone here tune some codes out?
    Nov 2011
    NY
    Sad news!...
  6. #6 Re: Can anyone here tune some codes out?
    Omaha, NE
    Quote Originally Posted by coolone View Post
    Sad news!...
    Right? He said that he has a few PCMs left and once they're gone, he is calling it quits.
  7. #7 Re: Can anyone here tune some codes out?
    Bastard Reptile's Avatar
    Kansas City, MO
    It's probably not the wiring. The sensor reluctantly tries to keep up to temperature because it's farther down stream with headers. It's actually very common.
  8. #8 Re: Can anyone here tune some codes out?
    Kansas City, MO
    Sad news!...
    Yeah, a sign of the times I think.
  9. #9 Re: Can anyone here tune some codes out?
    Donating Users timboku's Avatar
    Montgomery, IL
    I work in Joliet and can remove the codes so you can pass emissions, but you have a different issue....did you check make sure your wire harness for 02 isn't Burnet or grounding out? What brand 02 sensor you buy? Did you check fuse 21 under hood make sure that's not blown? Did you put SD headers on? Did you bang tunnel so 02 sensor doesn't hit the tunnel?
    Sent from my SM-N910V using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  10. #10 Re: Can anyone here tune some codes out?
    May 2015
    Quote Originally Posted by timboku View Post
    Nope I went through and checked for burnt wiring and didn't see anything. I made sure to zip tie everything away from the exhaust. I do have the zzp o2 extension and a stock o2 sensor that I actually purchased from Reptile about a year ago. I do I have SD headers and I have a couple of cm of clearance. When I replaced the dog bone bushings with urethane I made sure to rock the engine back and fourth multiple times and from what I could tell there was no contact with the firewall.
  1. 2004 Gtp tripped a bunch of codes after a full write tune
    By BoostedPontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2016, 01:14 PM
  2. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  3. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  4. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  5. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
