Thread: eddies table modifier thingy?
Results 1 to 10 of 10
  1. #1 eddies table modifier thingy?
    Nov 2012
    pistolvania
    using this on windows 10 scanning with uvscan2 . i import my scan import my maf table and when i try to export the new maf table it keeps coming up with error ........an unhanded exception has occurred in your application.if you click continue the application will ignore this error and attepmpt to continue....cast from string '''''''to type double not valid........anybody ever encounter this and know what to do next
  2. #2 Re: eddies table modifier thingy?
    try a different version of uvscan, theres a few of them out there. or use the dhp scanner.
  3. #3 Re: eddies table modifier thingy?
    Nov 2012
    pistolvania
    any links by chance
  4. #4 Re: eddies table modifier thingy?
    drop box might have one, or google searches.
    drop box link is a sticky in this section
  5. #5 Re: eddies table modifier thingy?
    https://www.dropbox.com/sh/wzgpgl5kx...h-89aKdOa?dl=0 i uploaded the two i have to dropbox. see if these help.
    i have both of these loaded on my laptop, for the life of me i cant recall what one works better, one used to freeze up on me and have scan errors, the other dont.
  6. #6 Re: eddies table modifier thingy?
    Buffalo
    I miss the days Eddie posted
  7. #7 Re: eddies table modifier thingy?
    Nov 2012
    pistolvania
    crap neither worked the one said class registry error when opening. the other installed and when i try to import my scan into table modifier it says 5548 bad lines on scan were not imported.any help....maybe windows 10 is the issue
  8. #8 Re: eddies table modifier thingy?
    when it says bad lines you got a bad scan some how. get that crap all the time with eddies tho.
    if your using dhp, scan with dhp, export that scan, its as good as uvscan to me, its all i use cause uvscan is full of issues.
  9. #9 Re: eddies table modifier thingy?
    Nov 2012
    pistolvania
    i tried scanning with dhp but when i went to disconnect and save the bar that fills up while saving had one block left then froze ..... i just want to 0 my fuel trims ...why god why
  10. #10 Re: eddies table modifier thingy?
    mine will hardly ever lock up saving, but when it does, the scan is still in logs.
    if you ever played with the settings for the scan that might be why. also make sure your running dhp as admen. try that with uvscan too, cant hurt. just right click the icon and run as admen.
  1. Eddie's table modifier
    By CrazyGuy03 in forum PCM Tuning
    Last Post: 09-02-2016, 11:42 PM
  2. Eddie's table modifier
    Last Post: 09-02-2016, 11:35 PM
  3. Eddie's Table Modifier
    By Nighthwk12 in forum PCM Tuning
    Last Post: 07-18-2013, 09:21 AM
  4. UV Scan and The Table Modifier Thingy
    By LapeerGTP in forum PCM Tuning
    Last Post: 08-10-2012, 02:35 PM
  5. Eddie's table modifier, my table too big?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-06-2008, 09:00 PM
